1971 Cutlass S headlight harness routing
Old Jan 27, 2020 | 06:43 PM
72cuttys's Avatar
What is the factory way of routing and securing the headlight harness? I have had the car disassembled for so long I honestly have no recollection of how it was ran or secured to the body...
Old Jan 28, 2020 | 04:13 AM
The harness is run in a channel on top of the inner wheelhouse. It’s held in place with plastic clips that snap in place along the channel.
Old Jan 29, 2020 | 06:59 AM
72cuttys's Avatar
How about the front of the car along the core support from the driver side to the passenger? Along the top, bottom, etc
Old Jan 29, 2020 | 07:36 AM
Schne442's Avatar
No it's not a parts car!!
The Harness runs along the back of the top of the core support under the Radiator support ,with the harness clips plugged in the holes it then runs under the support above the back of the headlights and the clips plugged from the back side
Here are a couple of pictures where you can see parts of the harness and its location (not the greatest pictures of the Harness specifically) In the first picture you can see the harness running along the back of the Core support and once it gets past the Condenser/Radiator it drops down and under the support and the clips plug from the inside out
the second picture you can make out a bit of the harness and one of the clip points above the Battery
this is from a 72 but 71 should be the same
Old Jan 29, 2020 | 12:51 PM
72cuttys's Avatar
This is a TON of help. THANK! YOU!
Old Jan 29, 2020 | 03:01 PM
Schne442's Avatar
If you need a more detailed picture let me know and I will take some for you
Old Jan 29, 2020 | 03:14 PM
1971 Factory Assembly Manual
Old Jan 30, 2020 | 06:37 AM
72cuttys's Avatar
This is awesome, where can I find a copy of this manual?
Old Jan 30, 2020 | 08:30 AM
Schne442's Avatar
Any of the Oldsmobile Parts suppliers sell them or just look on Ebay under 1971 Oldsmobile cutlass assembly Manual
Old Jan 30, 2020 | 06:04 PM
72cuttys's Avatar
Is this the correct strap?
https://www.opgi.com/ignition-electr...h-c241066.html
Old Jan 30, 2020 | 07:04 PM
I believe that strap is to contain the wire loom which runs down the valve cover on the driver side. Note the strap attaches to the metal bracket. The metal bracket is attached via a valve cover bolt, then the strap is inserted into the metal bracket. See Figure 3 contained on Page 386 of the image I posted (above) - Post #7. I believe the OPGI strap is a universal strap. The original strap (and one you may obtain from perhaps another vendor) has additional holes for securing additional wires (based upon the sizing of the wires, gauge wires, etc.) as the size of the wire loom itself would increase in diameter which would run along the valve cover based upon RPO engine, accessories, etc. It will certainly work, but I do believe it is not of the OEM styling. The harness which runs under the radiator shroud is contained via clips rather than straps.
Old Jan 30, 2020 | 07:16 PM
Depending on how 'authentic' you intend to be (are you planning on having your car officially judged?), you can also use braided chrome, braided aluminum or plastic wire loom material and w/ the use of basic clips attached to the valve cover bolts you can secure the wire loom very nicely with nothing more than black plastic straps found at any hardware store. Whatever you choose to employ, it's always nice to view a tidy organized engine compartment/bay.
Old Jan 31, 2020 | 04:18 AM
rand5204's Avatar
The "correct" straps for this application are white in color and can be purchased from Inline Tube or Parts Place and probably others as well. Be a little careful with OPGI. They have a the largest assortment of parts out there but are also the most expensive - sometimes by a mile. Shop around before you buy.
Old Jan 31, 2020 | 05:23 AM
Schne442's Avatar
AMK Products Inc. is one of the best vendors for reproduction Hardware, once you have your Assembly manual all of the part numbers for clips screws nuts bolts are in there
AMK does not carry everything for Olds but they do have most of what you would need
they sell in Bulk or Kits so the prices are very reasonable compared to purchasing from other vendors
Downside is they have a $40.00 Min. on orders IIRC
Check out their online Catalog at
www.amkproducts.com
Old Jan 31, 2020 | 07:01 AM
Schne442's Avatar
Don't get confused, If you have any of the old straps or any hardware you can match it up with the Full size Images in the AMK catalog
I know you are asking about 1971 model Per-say and I have provided pictures of a 72 But research has shown that 71-72 were mostly identical on most of the clips,straps and hardware
My Original straps on my 72 were Black, all of the Supply houses have them listed as 71-72 and they are also black never seen a white one,unless he is referring to the white clips that are used with the Black wiring tape which was not used on the Headlight harness
No offence to rand5204
Ctls442
Jul 26, 2015 10:58 AM
Pewter442
Jan 3, 2015 08:39 AM
Retro1964
Jul 25, 2012 02:12 AM
kips70cutty
Aug 18, 2011 06:39 PM
1BAD68"S"
Nov 9, 2006 04:30 AM
