1970 olds cutlass Flasher
Old Oct 24, 2019 | 03:49 PM
Hondo's Avatar
Cool 1970 olds cutlass Flasher
I just pulled out the OLD Signal Stat 170 12V Flasher, and Advance dude sold me a EL12 round Heavy Duty Flasher?
Is this the okay to use? look at picture of old and new..
Thank You
Old Oct 24, 2019 | 04:13 PM
One sure way to find out is to plug it in.
Old Oct 24, 2019 | 05:08 PM
Hondo's Avatar
Cool Vintage Chief
Come on,,, Vintage Chief, I Need to know BEFORE I Blow something up.
I need Expert answer..
Hello anyone changed their flasher..
Old Oct 24, 2019 | 06:26 PM
I'm an expert at looking things up:
https://www.autozone.com/electrical-...-el12/849385_0
Here's a half dozen from RA which work - yours is listed - you might begin doing your own research (maybe before you purchase a part).
https://www.rockauto.com/en/catalog/...,flasher,10139
NAPA says it fits your vehicle:
https://www.napaonline.com/en/p/NF_EL12
O'Reilly Auto Parts says it fits your vehicle:
https://www.oreillyauto.com/detail/b...r/el12/4542954
I'm going to assume the salesperson at Advanced Auto was correct selling you this unit.
As I said previously - Post #2 (above).
I don't know, since I'm not expert, how many worldwide international companies manufacture signal flasher units for a 1970 Oldsmobile Cutlass and I'm not certain how many of these manufacturers have changed the part number of the units they manufacture and/or provide upgrades to the original parts they manufactured (if they have upgrades available).
There is also information (for free) on the Internet in which you can review part numbers and customer reviews to make informed decisions. This part number is an upgrade to previous model numbers and I am not going to perform research to determine what the benefits are of this particular model and manufacture.
Please refer to Post #2 (above).
Old Oct 24, 2019 | 07:25 PM
Hondo's Avatar
Wink Norm so what your saying is I wont blow anything up.. thank You
thank YOU
Old Oct 24, 2019 | 07:27 PM
Hondo's Avatar
Thumbs up Norm, another question?
Should I add some kind of electrical grease, because the old one I took off broke the Spade connector in the fuse panel and I had to slowly but carefully remove it..
Thank You Again
Old Oct 24, 2019 | 07:30 PM
Nothing will blow up - your previous flasher is a thermal flasher this upgraded flasher is an electro-magnetic (mechanical) flasher w/ a longer life span. This type flasher (generally) replaces flasher in vehicles post-1990 when LED lighting became available. This EL12 will operate for LED bulbs if you elect to employ them.
Old Oct 24, 2019 | 07:32 PM
Thank You Again
I always use a dab of dielectric grease on the blades. Just enough to coat the blades before you insert the flasher. I always use a dab of dielectric grease whenever I have electrical components on motorized vehicles which come into contact w/ each other.
Old Oct 24, 2019 | 07:34 PM
.... I took off broke the Spade connector in the fuse panel...
I recall from your other thread you had an issue getting it out. Glad you succeeded. Anything nearly 50 yrs old sitting in the same blade container is bound to present a battle.
Old Oct 24, 2019 | 07:36 PM
Sure, electrical grease will help the person who replaces the flasher 40 years from now.
Old Oct 24, 2019 | 07:41 PM
LOL LOL
You are correct about that, Ken. More so, whenever I have the chance to apply dielectric grease I always ensure I use it on any bulbs & sockets - as it will certainly reduce the timely effects of moisture leading to corrosion.
Old Oct 24, 2019 | 09:17 PM
Hondo's Avatar
Thumbs up Vintage Chief
LOL LOL
Yes when I tried taking it out, one of the prongs was stuck inside Rusted like crazy, with a small needle nose and a little help it came out.
Thank you very much for all the HELP I Thank you again..
P.S. hopefully the Flasher will work now....
fourohorsefarm
Oct 5, 2016 07:42 PM
notrecat
May 9, 2013 07:07 AM
Cameo White
Sep 20, 2010 07:54 PM
Palatin
Jun 2, 2010 02:28 AM
bjtstarfire
Jan 27, 2007 03:14 AM
