1970 442 Wiring Identification
Old Nov 30, 2024 | 09:04 PM
70_455's Avatar
Hello
In pic one on the A pillar, what is this wiring for?
In pic.2, Does anyone know what those white and black wires are for? Could it be for door jamb switch?
If it is, does it plug into the harness with a factory connector?
Mine door switch is currently unconnected with non factory wires..not whats in the pic.
Old Nov 30, 2024 | 09:09 PM
VI Cutty's Avatar
The first picture wire is for your rear view mirror map light. Wires in the second picture don't look original.
Old Dec 1, 2024 | 06:25 AM
White wires at the door pillar are typically the ground side of the dome/courtesy light circuit and go to the pin switch on the door jamb. As noted, these don't really look like factory wires, but it's hard to tell in the photo.
Old Dec 1, 2024 | 09:00 AM
70_455's Avatar
Would anyone have the pin connections or a picture of that door jamb switch? Do the wires that connect to the door jamb switch use a factory connector to go into the harness or are they connected to the harness directly?
brock1030
Mar 26, 2024 12:33 PM
442crzy
Feb 7, 2024 04:48 PM
madmax442.com
May 1, 2023 10:51 PM
cdrod
Aug 23, 2021 06:40 AM
Malcolm11
Mar 28, 2020 06:55 PM
