1970 442 W30 electrical problems
Old Oct 27, 2008 | 04:00 PM
daniel's Avatar
i have a 1970 442 W30 that will start with the altornator plugged in, but when i go to shut the car off, it wont stop running, the car will start with the altornator unplugged, and will shut off with the altornator unplugged, but eventually my battery will die, from not having the altornator plugged in. what can i do to fix this?
Old Oct 27, 2008 | 10:52 PM
BILL DEMMER's Avatar
Just the facts...
i would start with tracing the ignition wiring. the ignition circuit power supply is cut-off by the ignition switch, which then is supposed to ground the power wire to the ignition coil + terminal.
bill
Old Mar 11, 2009 | 01:33 PM
stellar's Avatar
stellar
sounds like 1 of 2 possible things. Either way your alt is feeding ign circuit. Either the #1 wire is shorted to ign feeding coil or someone needed a wire that was powered with the key on to feed the #1 alt wire and spliced into the ign wire. Does this car have an alt idiot lite that isn't working or is it OE with guages?
chasman414
Jun 25, 2020 07:05 AM
Hurst/Olds 73/74
Oct 16, 2014 06:22 AM
bpnoel
Aug 27, 2010 08:11 AM
65topless
Jul 6, 2007 01:55 AM
jf857
Apr 28, 2006 07:24 AM
