1970 442 tach
I have not, but I saw some posts here regarding that a while ago. You may have to search a bit for it. From what I remember, the results were favorable and just a swap out of the board that you get.
I got my replacement board from the cajun tach shop, it swaps out fairly easy the only problem was the studs were put in the board backwards just need to be swapped to the correct side of the board.
