1969 cutlass s: temp sender
Old Apr 24, 2011 | 05:33 PM
junkman454's Avatar
is a 69 cutlass S temp sender supposed to be a one wire or 2 wire when workin with a idiot light? ordered new from fusicks and sent me a 1 wire.but i have a extra blue wire taped back in the alt harness and have seen 2 terminal ones for sale at pepboys.
Old Apr 24, 2011 | 06:50 PM
Pretty sure the temp sender is the same basic thing in all the cutlass lines 68-70's. To the best of my knowlege the ones with idiot lights came with one wire from the factory. The information is on page 12-76 of the 72 Chassis Service manual. It clearly shows a single spade contact on the top of the senders. Hope this helps.
Anyone with a 69 manual might be able to confirm this.
Old Apr 24, 2011 | 07:35 PM
Beob's Avatar
Should be one wire, the extra wire might be for the oil sender. Is yours plugged in?
Old Apr 24, 2011 | 08:19 PM
junkman454's Avatar
.Thanks for info so far,
the oil sender is hooked up and has the original rubber boot and metal wire tag and the wire goes up to firewall,on the temp sender it has the light green wire on the sender,the extra wire in the same bundle with alt wires is blue ,the same length as green and shows with my meter as going to ground.
Old Apr 25, 2011 | 04:44 AM
Alb's Avatar
Alb
temp sender
On my 69 cutlass the temp wire is green and the oil pressure is blue. Just did a complete rewire of the car. Tried to start it and it didn't catch on fire.
Alb
Old Apr 25, 2011 | 05:44 AM
junkman454's Avatar
oil and temp ok, but new unknown plug
, problem solved green was temp, blue tied back wire was oil, now heres a pic of the connector that was hooked to oil sender, black wire and when tested to 12v + i show 7vdc. Traces back to firewall.
BeenThere
Jul 28, 2015 01:58 PM
rr69ho
Mar 23, 2014 10:21 AM
StickW31
Jan 6, 2013 06:46 PM
tpawlik
Jun 10, 2011 10:00 PM
Satellitecentral
Oct 15, 2008 08:15 PM
