1968 Speaker Question
Old Nov 20, 2016 | 10:33 AM
4424mike's Avatar
I recently installed a 68 am/fm delco from a cutlass in my car and wanted to hook up 2 speakers under the front buckets. I'm getting conflicting information on the correct speakers to install... some say 8 OHM and some say 10 OHM.
Which is correct? Thanks!
Old Nov 20, 2016 | 04:12 PM
Should be 10 ohm, 8 ohm will work as long as your cranking the volume way up as it will damage the output transistors.
Old Nov 20, 2016 | 06:07 PM
VC455's Avatar
Barely Registered
On Delco radios of that vintage, the output transistor circuit is tuned for 8-Ohm speakers. If you use 10-Ohm, you will need to retune (rebias) the output transistor collector. If you don't, you will have poor output but there will be no radio damage.
There have been a lot of new speakers sold where the resistance does not measure what they claim. Check your speaker coil with the speaker disconnected from the radio. The speaker coil must measure 1.5 Ohms. If it is 1.3 Ohms or less, it will overheat the output transistor stage and could draw so much amperage that the 12 Volt supply wire to the radio could be damaged.
Old Nov 20, 2016 | 06:32 PM
steverw's Avatar
Everything i have read about replacement speakers say 10 ohm.
Old Nov 21, 2016 | 10:49 AM
4424mike's Avatar
Thanks!
Big Mikey
Mar 14, 2021 10:18 AM
dnmfranco
Apr 25, 2014 07:34 PM
Hairy Olds
Mar 29, 2014 07:55 PM
Hairy Olds
Mar 29, 2014 04:26 PM
wyteon
Sep 3, 2012 11:54 AM
