1968 cutlass s charging issues/horn relay
Old Jan 18, 2014 | 11:36 AM
68Dreams's Avatar
Okay guys I have a 1968 Cutlass S I'm trying to figure out what wires go where on the horn relay. I had issues charging my battery have replaced the battery alternator and external regulator. With the test light I actually found one wire that i never connected to the horn relay but everytime I connect this wire it shoots up the volts to about 16 to19
So I was going to ask if anybody has a diagram for a 1968 cutlass horn relay. don't really know how many wires are wrong so any help would be appreciated
Old Jan 18, 2014 | 12:07 PM
sammy's Avatar
Sammy70 455 Supreme
Go to WAC and you can download the diagram for free..
Old Jan 18, 2014 | 12:20 PM
allyolds68's Avatar
Unfortunately the resolution isn't good enough to read it.
PM me with your e-mail address. I have a high resolution scan of it.
Are you running a 1 wire alternator now? If so the wiring diagram isn't going to help you with the voltage issue. If I remember correctly in a 1 wire alternator the wire goes directly to the battery. It actually is usually attached to the relay but the wire from the battery connects at the same spot
edit:
Somewhere on ClassicOlds there is a wiring diagram for what to do with the extra wires after you eliminate the external regulator (if that's what you've got)
Old Jan 18, 2014 | 01:27 PM
68Dreams's Avatar
Email address is kiecastillo@yahoo.com[/email] and I have the old set up the two wire clip with one battery wire
Old Jan 18, 2014 | 06:46 PM
68Dreams's Avatar
Relay confusion was a success big thanks to all who responded, Mike K thanks for the diagram was a big help in completing this headache.
88jetstar
Apr 28, 2014 10:28 AM
sunsetlimited
Jun 28, 2013 08:12 PM
OldsNoob
Apr 6, 2013 01:04 PM
tcarroll
Jul 16, 2012 04:21 PM
Clydemeness
Mar 14, 2012 09:10 AM
