1968 442 headlight problems
Old Sep 12, 2011 | 01:41 PM
bryndalfly's Avatar
when I turn on my headlight switch no lights come on, but when I turn on the high beam floor switch all 4 lights come on. Any ideas as to how to fix this?
Old Sep 12, 2011 | 01:46 PM
66ninetyeightls's Avatar
Land Yacht Captain
When you say no lights do you mean the interior lights don't work as well? Are you sure both low beam bulbs are good? Maybe the low beam filaments in the bulbs are gone. They would still work on High Beam.
Old Sep 12, 2011 | 01:51 PM
bryndalfly's Avatar
thanks Craig, good suggestions. Not sure as this is my brothers car in Indy and I am in Ohio so I will ask about that. I'll let you know what happens.
Old Sep 12, 2011 | 02:41 PM
frankr442's Avatar
I had a bad dimmer switch in my 71 that killed all the headlamps when I hit the high beams.
Old Sep 12, 2011 | 03:29 PM
jaunty75's Avatar
My thought as well. Replace the dimmer switch. It's not much money ($10) and easy to get at, and I'll bet that 90% of problems like you describe are due to a faulty one.
Old Sep 13, 2011 | 07:50 AM
It could be one of several things. The dimmer switch could be bad, both low beam filaments could be burned out, or the wire between the dimmer switch and the headlights could be bad. There was a thread here several months ago with a similar problem that turned out to be a bad terminal in the firewall connector.
Old Sep 13, 2011 | 07:52 AM
By the way, this is a classic example of where a little troubleshooting should be done before buying any parts. Check for voltage at the headlight low beam connectors first. If you have voltage, the bulbs are bad. If not, check for continuity across the dimmer switch terminals. If the switch is good, then the wiring is bad.
Old Sep 13, 2011 | 07:57 AM
dejavu442's Avatar
I had a similar situation when I was replacing the front bumper and front grillwork on my 68. In my case, it was simply the grounding wire was not tight.
Old Oct 4, 2019 | 06:40 AM
JCMC64's Avatar
JC
I'm having this exact problem. Was driving last night, took an aggressive corner off a turn lane red light, got a little sideways, straightened her out and out go both low beams at the same time. High beams make all 4 lights come on. Haven't t/s it yet, but my first thought was to check the voltage going into the low beams.
Old Oct 4, 2019 | 09:03 AM
That is exactly what you should do first. The only possible causes are both lights are burned out, dimmer switch is bad, or there is a break in the wire from the dimmer to the lights.
Old Apr 11, 2020 | 03:52 PM
Billyaxe's Avatar
Hey guys, having this exact problem. Gonna troubleshoot as advised. Did two of you resolve the problem and what was it? —Billy
Old Apr 11, 2020 | 10:48 PM
JCMC64's Avatar
JC
My issue were two fold...the front harness somehow came loose at the firewall, disconnected on the hard turn mentioned above. Got home and checked it out and found it. Other problems with turn signals was I had reversed the wires in one turn signal plug after restoring it.
Old Apr 12, 2020 | 04:19 AM
Billyaxe's Avatar
Thanks. Oh wow. I’ll start with checking my turn signal wires which I just put back after reassembling the front end. —Billy
Old Apr 12, 2020 | 03:27 PM
Billyaxe's Avatar
Thanks guys. I checked things out and got no voltage between the high beam button and the low beam lights. So ran a new wire and now it’s working. —Billy
Old Apr 12, 2020 | 08:29 PM
JCMC64's Avatar
JC
The turn signal wire issue was a seperate problem, blinkers did work ok except on the one where wires were crossed. On that one blinker stayed solid when selected, no blinking.
So not actually related to the headlight issue. Sorry for the confusion.
Thybigwheel
Jun 21, 2014 12:35 PM
Raydermiike
Nov 16, 2013 08:31 AM
patmills
Dec 6, 2010 06:01 AM
cutlass47
Nov 6, 2010 07:39 PM
TripDeuces
Aug 3, 2010 07:20 AM
