1966 Cutlass Vert rear courtesy lights.
My 1966 Cutlass Vert rear courtesy lights are inoperative when a door is opened or the light switch is rotated. First step is how do I access those courtesy lights in the rear arm rests. I have looked in my CSM and my Fisher Body manual and find nothing that to relates to the convertible application. Need some help please and hopefully some pictures.
Wayne
Wayne
Been awhile, but as I recall you'll need to remove the rear seats, or at least the bottom, and locate the screws that hold them in place. Remove and start your t shoot process... did you check bulbs first by removing lense covers?
literally just did this yesterday on my convertible. i replaced the dash/panel harness last year, i finally got the courtesy lites in rear armrests and under dash to work for first time in 32 years. small flat screwdriver pops out the lenses. its a small bulb, L90,
i pulled rear bench out and had to remove armrest bases to check wiring. also theres a connection under the bench where those orang/white wire connect to the "ribbon harness"that feeds the dash harness.
now my 4 courtesy lites work when a doors open, but nit when i turn the headline ****, im still working on that. but im just happy to have them switch on with a door.
Well I opened the lens in the armrest courtesy light. No bulb and I will pick up some #90 bulbs tomorrow. The socket looks OK. Did try to test with my meter but got no response. Looks like the socket is partially plastic. One wire I can see so for. Just in case does anyone repo the socket with wire.
Wayne
Wayne
So, just got back from O'Relly's AP with a package of #90 bulbs which are specified by my 66 CSM as the correct bulbs for the courtesy lights. Bulbs have two contacts on them. My rear courtesy lights have a single sprung pole in the center.
So just got out of the garage. Pulled out the light assembly. It has two wires, one white and one orange. Obvious that a two pole #90 wasn't going to work. I had some #97 single from my license plate light so I tried one and it fit correctly. No light. Put my multi meter to it and no results.
Obviously something is not hooked up correctly. I will have to wait until spring when I do the carpets and have a better view.
Any comments or ideas.
Wayne
Wayne
my 66 original courtesy light sockets definitely have two contacts in the base. the two lites in rear armrests, and the two under the sides of dash were the same. Maybe yours were replaced, or possibly one contact was broken?
Mazey, you are probably right about the replacement. Won't know for sure until spring when I expect to redo my carpets and seat belts. I have to look under the dash at the courtesy lights and see what mine look like. Hopefully still original. I think Lectric limited makes the correct harness for the fronts so I can do something with the rears. Thanks for your info. I will continue to look for more information. Maybe someone has a nice used set available.
Wayne
Wayne
