Air Shocks for a 74 88 Conv
Old Aug 3, 2015 | 11:33 AM
1yesfan's Avatar
Can I buy air shocks that would fit the rear of my 74 olds. I don't like how it sits so low. I suspect I won't find NEW correct fit springs and even new normal shocks would not raise like I want.
Old Aug 3, 2015 | 03:06 PM
GABRIEL 49131 or other brand equivalents.
Old Aug 4, 2015 | 05:42 AM
1yesfan's Avatar
http://www.ebay.com/itm/Shock-Absorb...-/390747661408
On Ebay it say these are not compatible with my 74 Delta 88.
Old Aug 4, 2015 | 06:47 AM
That's the number that came up with my search. Go to your local autoparts store and have them look it up. Air shocks should be readily available.
Old Aug 4, 2015 | 07:20 AM
Rear shocks are interchangeable between essentially all GM full size and mid size cars from 1959 to somewhere in the '90s.
The factory made lots of subtle valving changes, but most aftermarket shocks are spec'd for all of them.
If you don't find a '74 Delta on the list, check for a '71-'76 Impala - they are identical.
Old Aug 4, 2015 | 09:36 AM
1yesfan's Avatar
thanks for the info
Old Aug 4, 2015 | 09:43 AM
Local Hero's Avatar
I always felt that air shocks were good if you needed the ability to adjust the ride height such as when carrying a heavier load on a trip, or towing a boat or small camper. In the case here, I get the impression that Tim is not happy with the ride height of the car ALL the time.
If so, my opinion would be to replace the rear springs instead. They are available.
http://www.napaonline.com/Catalog/Ca...199_0162297072
They'd last longer than the shocks will since air shocks can be prone to leaking over time. A stock replacement set of springs wouldn't cost much more than the shocks and be a better "fix" in the long run.
But I agree with the above. If your heart is set on air shocks, all the GM big boats used the same ones.
Old Aug 4, 2015 | 10:00 AM
1yesfan's Avatar
I was under the impression it is hard to find springs for these now that are the right "spring rate" or I could end up with two diff springs??? Are they the same for Convert or HT?? Where can I find springs then? I just thought the air shocks were a easy way to get the car up a little more. If i put the slightest amount of weight in the car it really sits low. looks stupid. I never get any bottoming out though.
71RadioflyerVista
Suspension & Handling
Mar 14, 2011 11:00 PM
Summerof84
Apr 27, 2010 05:16 PM
montvaleplace
Feb 10, 2010 09:12 PM
WEBBISH
Brakes/Hydraulic Systems
Dec 13, 2008 03:35 PM
Pghstarsky
Jan 18, 2008 04:21 AM
