1963 dynamic 88 door hinge kit
You probably won't find a kit labeled for that car, but there are only a few different bushings and pins used by GM. Just measure the ones you have and buy the bushings and pins as needed. You can get longer pins if necessary and cut to fit. Dorman has a selection of different bushings and pins, for example. Clips and Fasteners is another possible source.
https://www.clipsandfasteners.com/Do...hings-s/85.htm
Chevy door hinge kits fit .
I used them on my '63 Dynamic 88 .
1961-1964 Chevy Door Hinge Pin Kit (ecklers.com)
