Will 63 88/98 Fenders fit a 64 J88?
Old June 19th, 2016, 05:09 PM
jetstar88convertwi's Avatar
A local guy has 2 sets of front Fenders for sale. One set is from a 63 Super 88 and the other set are from a 63 98. Will these bolt up to my 64 Jetstar 88?
Last edited by jetstar88convertwi; June 19th, 2016 at 05:11 PM. Reason: sorry double post. stupid phone
jetstar88convertwi is offline
Old June 19th, 2016, 07:05 PM
sorry about the double post.
Darn phone. I hit submit, it posted and went back to the submit page so i thought it didn't work so I did it again.
Old June 19th, 2016, 07:30 PM
Phantom Phixer
Charlie Jones's Avatar
In the Olds parts book the 63 and 64 carry different parts numbers . So there had to be some difference.
The fender extensions (end caps) are obviously different , but the fenders themselves look the same in pictures I have seen. I don't know about how they mount up to the inner fender though.
They look close enough that it may be worth putting them side by side and comparing and measuring them carefully. You may find that the 63 fenders can be used with minor modification. Or not.
If you do this , let us know how it turns out.
Just took a look at the parts book again , and I noticed that the gasket between the fender and the fender extension is different for 63 and 64. That's probably where the difference is .
Charlie Jones is online now
Old June 20th, 2016, 05:13 AM
Oldskeeper's Avatar
They fit, with a little adjustment. I added 64 98 fenders to a 63 98 and the only change required was the nose cap. So going the other way using 63s for a 64 should work, the bracket at the cowl might need to be altered if I remember correctly I had to shim up the 64s to fit on the 63.
Steve
Oldskeeper is offline
Old October 29th, 2016, 02:10 PM
Forward into the Past
Human's Avatar
They should bolt up although the contours at the front corners are a little different. The '63s overhang the headlights slightly, giving it a little more formal look while the '64s are slightly swept back, giving a somewhat more aerodynamic appearance. A lot of the sheetmetal is interchangeable. My '64 had a '63 trunk lid on it when we first got it.
Human is offline
jetstar88convertwi
January 2nd, 2017 06:38 AM
88jetstar
June 2nd, 2014 10:36 AM
88jetstar
April 22nd, 2014 01:43 PM
rennoc442
August 30th, 2013 09:23 AM
aliensatemybuick
September 23rd, 2010 01:05 PM
Quick Reply: Will 63 88/98 Fenders fit a 64 J88?
