th400 shift shaft seal
![Smile](https://classicoldsmobile.com/forums/images/icons/icon7.gif)
![Confused](https://classicoldsmobile.com/forums/images/smilies/confused.gif)
wr5ong wrong question!!!!! sorry
the question is if I can operate from the outside for resealing the shift shaft or if I must remove the transmission oil pan and replace the seal from the inside
I have not idea of what the tool is like, so I do not know what searching about, some friend of mine have said that I can use a bolt the same measure of the O-ring seal to push it inside without remove the old one so the new seal comes in addition to the worn old one
???????? possible???
2 screws
I just did mine by drilling two very small holes in the metal rim of the seal and screwing two small screws to pull on. It was not easy to remove the seal and there's a good chance of scratching the housing. I would highly recommend the proper tool but since I'm El Cheapo I tooks my chances. So far so good.![Embarrassment](https://classicoldsmobile.com/forums/images/smilies/redface.gif)
I also bought the high performance rebuild kit on Epay for a very reasonable price. By the time you pay for each small seal and gasket you can purchase a whole kit. I also went with a new trans pan with a drain this time.
Thanks to Joe for this alternative method, he also cautioned on the housing damage possibility.
http://www.ebay.com/itm/Transmission...d0d423&vxp=mtr
And here is an explanation on how to use it - pretty slick!
http://forums.corvetteforum.com/c3-t...with-pics.html
http://www.jalopyjournal.com/forum/s...d.php?t=585104
64 CUTLASS KEN
November 22nd, 2010 05:17 PM
