Tachometer in your 50's Olds
Old Feb 27, 2023 | 07:53 PM
madmax442.com's Avatar
madmax442.com
Anyone want to share your tachometer mounting ideas? I am thinking of running a smaller, under 3 inch diameter pedestal mount on the column, really don't want to mess with the look on the beautiful dash, but I have got have a tach to drive it, tune it, etc. So basically, I am torn. Thoughts?
Old Feb 28, 2023 | 05:45 PM
madmax442.com
Ok, well here it is. It's pretty small, 2 1/2 inches. I think its gonna grow on me. We'll see.
Old Feb 28, 2023 | 07:37 PM
Is it a hotrod or a basic stock restored car?
Old Mar 1, 2023 | 11:16 AM
madmax442.com
No, its all original. I wired it with a 4 blade connector I can just take it out if purists are hovering at a car show.
Old Mar 3, 2023 | 08:28 AM
Tedd Thompson's Avatar
Why do you need a tachometer ?it's an automatic car and i will never be over revved and shifts itself when it's time to shift. I must be a purist then. To me, it looks out of place and just tacked on . To each his own. If you like it that's where it should be...Tedd
Old Mar 3, 2023 | 09:46 AM
madmax442.com
its quit on me a few times, hard to even tell if its still running, 400 rpm in drive. Ill pull it out before any purist looks at it! Lol thanks for the input.
Old Mar 5, 2023 | 10:45 AM
madmax442.com
Ok, column mount is out, just way too gawdy. I moved it under the dash, used the bottom screw for the ash tray, so no holes drilled.
Old Sep 13, 2023 | 08:21 AM
WikedOldsmoileSupe88's Avatar
The car I just bought had one mounted to the left of the steering wheel next to the window.
Cincinnati Rick
Sep 30, 2021 05:13 PM
425HP409
Oct 27, 2010 07:58 PM
alexrains
May 6, 2010 12:06 PM
rocketrickshaw
Jul 20, 2009 05:46 AM
todd66442
Mar 27, 2009 05:38 PM
