Shocks on a '54 Olds
Old Feb 25, 2009 | 06:45 AM
54olds's Avatar
Nothing new beats an Olds
Is there any way to re-condition the lever action front shocks on a '54 Olds? I'm assuming they use hydraulic fluid - can they be refilled? I can buy re-manufacturered ones, but they cost a small fortune
Old Feb 25, 2009 | 07:47 AM
redoldsman's Avatar
Proud Viet Nam Veteran
I am passing on a remedy I heard but have not tried. It came from a pretty good mechanic who has been around awhile. Take STP and heat it where it will pour and fill the shocks with it. It does sound reasonable and you are not spending a lot of money. I would be interested to know if it works. Remember, I have not tried this and am just passing it along.
Old Feb 25, 2009 | 09:17 PM
88 coupe's Avatar
Junior Member
Originally Posted by 54olds
Is there any way to re-condition the lever action front shocks on a '54 Olds? ........
There is. The process, as explained in the '50 and earlier shop manuals, is the same.
........ I'm assuming they use hydraulic fluid - can they be refilled? ........
They do, and they can. Hydraulic jack fluid is a close, if not exact, example of the original shock fluid. ATF is also an excellent substitute.
I used Jack fluid in several '49s and '50s, and ATF in my '54.
........ Take STP and heat it where it will pour and fill the shocks with it ........
Unless you think STP has the same properties as shock, fluid, jack fluid, ATF, or any other hydraulic fluid, I would not suggest using it.
Norm
Old Feb 26, 2009 | 12:09 AM
88 coupe's Avatar
Junior Member
Grab em while you can. They won't be up long.
Norm
Old Feb 26, 2009 | 06:13 AM
54olds's Avatar
Smile
Wow! Thanks Norm (and everyone else!)
I really appreciate the info!
Old Feb 26, 2009 | 06:16 AM
Oldsguy's Avatar
Past Administrator
I like that green/white paint scheme.
Old Feb 26, 2009 | 10:12 AM
54olds's Avatar
Thanks. It almost turned into a disaster, as I used s/s acrylic enamel and ended up with orange peel
Since you're not supposed to sand acrylic enamel, I shot it with about 4 coats of clear and wet sanded that.
Didn't turn out too bad considering what could have been!
holidaysedan
Dec 21, 2010 03:38 PM
Leroy701
May 5, 2010 06:01 AM
shovel55
Feb 3, 2010 08:34 AM
shovel55
Feb 3, 2010 07:22 AM
J'ville
Aug 19, 2006 01:07 PM
