Rocket, Super-Rocket, High-Compression?
Old Oct 12, 2011 | 08:51 AM
  #41
Mak's Avatar
Mak
Originally Posted by MDchanic
you MAY be able to advance to 7½°, but only if there's no detonation.
I finally got a chance to check the timing. It's currently set at 10* (@ 850rpm, w/ vac adv disconnected)... Hmmmm, seems like it should be pinging like crazy on regular fuel! I guess this engine was modified when it was rebuilt... sure wish I had more info on what was done. I guess I'll have to just adjust it by ear.
Old Oct 12, 2011 | 08:58 AM
  #42
Mak's Avatar
Mak
Originally Posted by 67442nut
It lists displacement, torque, horsepower, compression ratios, carb type and availability.
Thanks, that is very interesting info... I didn't think there was 425 HC w/ a 4bbl available, but looks like there was.
Old Oct 12, 2011 | 10:16 AM
  #43
67442nut's Avatar
If you mean a 425 HC with a 2-barrel carb, I thought the same thing until I looked more closely at the chart.
I also didn't realize the the Toro and Starfire engines were 10.5:1 like the 4-4-2.
I thought 10.25 was the highest CR in a 425.
Old Oct 12, 2011 | 10:35 AM
  #44
Mak's Avatar
Mak
If you mean a 425 HC with a 2-barrel carb.
I knew there was a 425 HC w/ 2bbl, that's what mine is (was). I didn't think there was a HC 4 bbl option, but looking back at the chart I see it now (prefix code R, no suffix code)
Old Oct 12, 2011 | 12:01 PM
  #45
10.25:1 was the standard compression, all others were by request.
Olds brand identity was "Ultra High Compression."
As far as your timing, there are two possibilities:
Your timing mark is off (it does happen), or
Your engine has had different pistons and / or head gaskets installed.
Did you ever look at the visible part of the gaskets to see if they were thin shiny metal or thick dull fiber?
Old Oct 12, 2011 | 07:36 PM
  #46
Mak's Avatar
Mak
Hard to tell for sure, but I'm guessing the thicker gasket's... lowering the compression ratio. Seems I've got a bit of Frankenmotor, lol... but, hey, I'm not building a race car.
That being said, I installed the Pertronix ignitor today (with the stock coil), replaced the cap & rotor, new NGK plugs (last week), adjusted the carb, set the base idle to 550rpm and the timing to 10* (I tried backing it down... not good), filled up with mid-grade (89) and went for a drive... it runs like a scalded dog! Much better throttle response, smoother idle, starts quicker... and NO pinging, not even accelerating up long grades. That's good enough for me... I'm closing the hood and moving on to other things (mostly interior projects). Thanks much for all the help & advise... I really appreciate it!
Old Oct 12, 2011 | 07:40 PM
  #47
Sounds great!
Enjoying the way it runs is what counts!
Old Oct 12, 2011 | 07:49 PM
  #48
Mak's Avatar
Mak
That Pertronix ignitor is really cool... easy install & really made a difference. I will be keeping my points & condenser in the trunk though... just in case, lol.
Old Oct 13, 2011 | 04:17 AM
  #49
To illustrate a point I made earlier, and that has been made by others when difficult-to-explain timing questions have come up, see this post from this morning.
It would not be unreasonable, in light of your good-running engine with timing numbers that shouldn't be, to double check the position of your timing mark.
Old Oct 13, 2011 | 08:31 AM
  #50
Mak's Avatar
Mak
Thanks for the info, I will verify the marks just to be sure. I think in my case, since were only talking about 2.5-5* difference in timing... and the fact that my engine runs great (no smoking, etc), that your earlier suggestion of thicker head gaskets or other engine modifications is more likely. The PO was a professional mechanic, and I'm thinking he may have purposely (or accidentally) set the engine up to run on lower octane fuel. He has since moved away and I have no way to contact him... but he gave me a folder of receipts. I found one from a local speed shop that did the machine work, it's hard for me make sense out of all the info listed, but I do see, among other things: 1 gasket set- Felpro (no part # though)... and resurface/milling .008. I'm probably letting my curiosity create a problem where there isn't one, lol. I'm gonna run 89 octane fuel and drive it!
Old Oct 13, 2011 | 08:50 AM
  #51
The factory head gaskets seem to be about 0.014 to 0.016" (though the manual says they're 0.025"), while the Fel-Pros are about 0.047".
Subtracting 0.008" milling, you get a distance of about 0.039", which is about 0.025" greater than stock, which adds about 5cc of volume, which will reduce the CR by probably a bit less than a whole number (ie: 10:1 down to 9.2:1 or something - others with the combustion chamber volumes at their fingertips can correct me).
It seems that the original CRs were a bit less than advertised (with production tolerances, better to have a motor that runs well than one that pings all the time), so I'd bet that's a reasonable guestimate of your current CR, which would explain your good performance on 89 octane .
Old Oct 13, 2011 | 09:05 AM
  #52
Mak's Avatar
Mak
The factory head gaskets seem to be about 0.014 to 0.016" (though the manual says they're 0.025"), while the Fel-Pros are about 0.047". Subtracting 0.008" milling, you get a distance of about 0.039", which is about 0.025" greater than stock, which adds about 5cc of volume, which will reduce the CR by probably a bit less than a whole number (ie: 10:1 down to 9.2:1 or something - others with the combustion chamber volumes at their fingertips can correct me).
Damn, your good!
Did I mention it'll do a wicked burn-out?! And that's what really matters!
Thanks again!
Old Nov 18, 2011 | 04:13 PM
  #53
KQQLCAT's Avatar
Why would they put the most HP in the Toro? Nice to know though I have access to that motor in my friends garage. We scrapped a 67 Toro and kept the motor.
Old Nov 18, 2011 | 04:23 PM
  #54
Ummmmm... Marketing?
Top-of-the-Line car gets most powerful engine.
Just a theory...
greenslade
Mar 29, 2011 03:56 PM
bobsrats
Apr 2, 2009 07:36 AM
tlucas07
Mar 23, 2009 11:40 AM
Redog
Sep 12, 2008 01:54 AM
