Rear seat
Old October 30th, 2008 | 08:40 PM
FATRATMATT's Avatar
Rear seat
Will the bottom rear seat out of a 4 door 88 fit into a 2 door car??? How about the top part of the seat will it fit also.
Old October 30th, 2008 | 08:45 PM
As long as it's from the same body style and compatible year it should be a slam dunk. What year is your 88? You could probably also fit rear seats from a 98 into your car if you wanted.
If you're trying to fit an 88 seat into an A body I don't think you'll be able to do it. Different interior dimensions.
Old October 31st, 2008 | 12:04 PM
FATRATMATT's Avatar
Yea both cars are a 68 delmont 88. I'm going to look at a car in Ohio and if it turns out to be the same color interior, then I'm going to get as many things as I can. Small items mostly... rear view mirror, kick panels, steering wheel, gear selector needle,wheel moldings, clock light wiring harness,and what ever else I can. This car is in a yard that only deals in GM cars from what I'm told. I'll take a lot of pictures, especially Oldsmobile.
Old October 31st, 2008 | 05:44 PM
blkmonday
Guest
Posts: n/a
the rear seats should be identical. i have a 66 dynamic 88 ragtop with the rear seat out of a 4 door...no problems...same speaker in the seat as well
Olds442redberet
January 14th, 2015 06:12 PM
mydadscutlass
July 16th, 2012 08:41 PM
68Tom
May 8th, 2012 07:41 PM
Nor Cal Andy
April 1st, 2011 07:13 PM
68Tom
September 16th, 2010 10:41 AM
Quick Reply: Rear seat
