rad question
Old Mar 12, 2007 | 03:01 PM
Joel n's Avatar
rad question
will all full size chev rads fit my 78 olds 88?? mine is leaking like a sive. iam not driving it right now anyway, but wanna get it back on the roads in the late spring.
Old Mar 12, 2007 | 07:12 PM
Redog's Avatar
www.jegs.com
There is a section under cooling that has a "Be-Cool" raditor that will fit the full size Delta for 78 to 85. You just gotta look under Caprice in those same years. This is the rad I have in my Delta
That is the same for a lot of part, except of the engine of course
Here's a pic on my rad set-up, other pics of the car are in my signture at the bottom of the post
If you can afford is, get the electric fan too, and the "Painless wiring" kit and the brackets for the fan, I put the fan in myself
http://memimage.cardomain.net/member...50_13_full.jpg
Old Mar 13, 2007 | 05:27 PM
Joel n's Avatar
thanks. lookin that up now. so if iam looking up parts, i can use caprice parts from that time?
Old Mar 13, 2007 | 06:48 PM
Redog's Avatar
Yeah, everything except from a Caprice will fit a Delta of the same year. Except of the engine and certain extior items like bezels.
If you get the rad on jegs, get the fittings too, you'll need them to hook up the tranny
Old Jul 26, 2007 | 08:18 PM
rfaller's Avatar
if you are running a stock motor, just measure your radiator and go to autozone and tell them what size you need(any autoparts store will do)i recently put a heavyduty 3 core in my z28 from autozone for 102.00. becool offered the same one for 595.00. i have a Becool in my prostreet camaro just cause its so pretty but i wouldnt waste money on a driver
Old Jul 27, 2007 | 07:20 AM
I just replaced the radiator in my 86 w/307 Olds motor. Should be the same radiator for your 78. I got mine from Advanced Auto Parts. $124 list and it was in stock. The original radiator was a 3 row copper unit. The replacement was a two row aluminum with crimped plastic end tanks. I was skeptical, but it was a drop-in and the car ran cooler on a trip from VA to upstate NY. Up and down the hills on I-81 at 75 mph, stop and go traffic at the construction sites, and A/C blasting the whole way. And, a lifetime warranty. I was pleasantly surprised.
JCMC64
Mar 13, 2012 09:24 AM
dephconn24
Body work
Feb 12, 2012 02:11 PM
katprice
Aug 14, 2011 09:37 AM
keyroc95
Dec 4, 2009 07:53 AM
GoldOlds
Oct 24, 2007 04:38 AM
