Pushing the cruise control button twice
Old Jun 21, 2016 | 04:38 PM
illumined's Avatar
1978 Ninety Eight
After getting the defective replacement lifters replaced I decided to go for a spin and at long last use the cruise control function that's been mostly unused for who knows how long (it was fixed last year, corroded fuse). Once I get up to speed and set the stalk switch to on, I push the engage button and nothing happens. I push the engage button again and then it turns on. Is it normal to need to push the button twice to engage it?
Old Jun 21, 2016 | 04:54 PM
Octania's Avatar
No. Maybe the main switch was off. first time should set the speed, 2nd time drop it 1-2 mph. Maybe it was just a delay.
Old Jun 21, 2016 | 07:03 PM
illumined's Avatar
1978 Ninety Eight
I'll try it again when I take it on the freeway again (hopefully tomorrow), if that isn't a delay then I'll take it to a mechanic. Thanks.
Old Jun 22, 2016 | 02:56 PM
illumined's Avatar
1978 Ninety Eight
You're right, it was just a delay, which I guess was a bit longer than I initially expected. Using the engage button to slow down works well. However trying to use R/A doesn't accelerate it but rather seems to disengage cruise control completely instead of increasing speed. Maybe something isn't right with that.......
Mark71
Apr 29, 2020 07:53 PM
yamahondarider
Feb 26, 2014 08:52 PM
ELECMAN
Jan 23, 2011 10:11 AM
Sid
Sep 27, 2010 07:55 AM
RAMOS_ANT
Sep 1, 2009 10:45 AM
