Power Seat Problem 1985 Delta 88
Old Apr 28, 2019 | 11:20 AM
Hammerdrop's Avatar
Angry Power Seat Problem 1985 Delta 88
I'm trying to remove a driver power seat complete and can't get the seat to motor forward in order to remove the second nuts from underneath the track at the rear. I have the 2 front nuts off and the inner 2 nuts off also at the rear, but how the hell can I remove the other nuts under the seat track in the rear? The car is being dismantled and I think the seat switch is inoperative. Or maybe applying power to which 2 seat switch wires would make the seat motor forward? I don't have a wiring diagram for this 1985.
And what about other options to accomplish forward movement. There must be a way to do this when the seat motor stops working.
Old Apr 28, 2019 | 12:02 PM
CRUZN 66's Avatar
Olds Fever
I could be mistaken, but I believe if you disconnect the drive cables from the motor you may be able to slide the seat manually...
Old Apr 28, 2019 | 05:41 PM
I went through this with TWO 1985 D88s. In both cases the seat was in the worst possible location. It took a lot of swearing and a selection of box and open end wrenches, turning the nut one flat at a time (if you're lucky). Usually it was turn the nut as far as you can, flip the wrench, repeat. I couldn't disconnect the drive cables with the seat out of the car, much less reaching under it blind.
I assume the plastic coupler is bad?
Old Apr 28, 2019 | 06:25 PM
Hammerdrop's Avatar
Hey Joe, the coupler is good; I can't get the fwd-rev motor to run with alligator clips. What color wires operate that function? I agree getting at those other nuts will be a real PITA. The dealer mechanics must have had a way to accomplish this.
Old Apr 30, 2019 | 06:50 PM
Hammerdrop's Avatar
Well, the solution here was to remove the seat from the base first and then, as Joe pointed out, just get an open end wrench under the track and get that last 13mm nut off a little at a time. Getting the seat off the base was not extremely hard. There is a 13mm headed bolt at each of the 4 corners. A mirror is helpful and 13mm 1/4" drive sockets short and long are required. Without removing the seat itself first, removal is probably possible with determination and a good flashlight.
Old Sep 23, 2020 | 09:54 AM
dinoedwards's Avatar
How about gear box housing? My is cracked and need a new one,,,any other options then plastic?
Old Sep 23, 2020 | 11:18 AM
Sugar Bear's Avatar
Since the car is being dismantled, can you cut the floor out around the rear mounting points to get better access to the nuts?
84deltaguy
May 24, 2018 03:23 PM
rand5204
Aug 29, 2016 03:59 AM
Oldsnut73
Jan 3, 2016 03:11 PM
Christophe2m6
Jan 30, 2015 02:08 PM
lonestarjarhead
Mar 17, 2012 11:34 PM
