M.D.S for a 75 88 convert
Old Sep 25, 2007 | 02:33 AM
shaunr's Avatar
i want to get a MDS system for my 350 convert. im not really sure which one to get. im new to this rebuilding and restoring hobby. Anyone with suggestions are greatly appreciated
Old Sep 25, 2007 | 05:18 AM
Oldsguy's Avatar
Past Administrator
Do you mean after market ignition? If so, you are probably referring to MSD. What year car are you talking about, pre factory HEI? You might do better just getting a factory HEI distributor or an after market Petroniks kit. Were you referring to just the distributor or the distributor and the control box? There has been some discussion about those here and if you do a search it might provide you some good research reading.
Old Sep 26, 2007 | 05:29 AM
shaunr's Avatar
i did mean MSD. thanks for the info, its for a 75 olds delta88 convert. i brought a brnd new crate engine for it, a 350. ive went to a couple car shows in my area and saw that there were a number of cars with the MSD. ive seen all kinds. im not too familiar with them yet.
Old Sep 26, 2007 | 07:25 AM
Oldsguy's Avatar
Past Administrator
Well, I am really not the type to purchase something unless it has a specific purpose or function beyond appearance. I would recommend that if you want to get an MSD ignition system then just contact them and order what you want as it applies to your engine. However, I don't think you could do any better than the stock distributor that your crate engine probably came with with the exception of not having to deal with points wear and the associated preventive maintenance that it occasionally requires. If you want to avoid that maintenance, then I would recommend something like a petronix retrofit kit, everything would fit under the distributor cap you engine has now.
Old Sep 26, 2007 | 07:39 AM
A 75 Olds should already have an HEI distributor.
Old Sep 26, 2007 | 07:47 AM
Oldsguy's Avatar
Past Administrator
He mentioned buying a crate 350 and I didn't know if it was a direct replacement or not. You are probably right that it would have an HEI distributor and in that case, no changes are needed.
Old Sep 27, 2007 | 02:52 AM
88 coupe's Avatar
Junior Member
Originally Posted by shaunr
........ car shows in my area and saw that there were a number of cars with the MSD ........
They have been popular, as appearance items, for many years.
If you are looking for a power increase, it won't happen.
Norm
Old Oct 1, 2007 | 12:43 AM
shaunr's Avatar
Thanks fellas
vistacruiser1971
Nov 9, 2013 01:19 PM
66olds98
Cars Wanted
Mar 30, 2010 07:53 AM
<1963 Olds Dynamic 88 Conv>
Mar 20, 2010 11:26 AM
chuck2
Jan 12, 2005 02:11 PM
ragtopqueen
Jul 22, 2004 06:49 PM
