Leaking gas tank at bottom 74 olds
Old Sep 9, 2011 | 08:45 AM
delta254's Avatar
Any suggestions on stuff to use to repair a leaking gas tank its not a whole more like a crack of some sort or maybe a pin whole? Besides buying a new tank for now I want to fix it.
Old Sep 9, 2011 | 08:53 AM
I've had good results with the 2-part epoxy gas tank sealer "clay" available at most auto parts stores.
Old Sep 9, 2011 | 09:07 AM
Blaster's Avatar
Old Sep 9, 2011 | 09:44 AM
delta254's Avatar
Originally Posted by mdchanic
i've had good results with the 2-part epoxy gas tank sealer "clay" available at most auto parts stores.
- eric
like jb weld stuff?
Old Sep 9, 2011 | 09:47 AM
Like that, but there's one that's supposed to be just for gas tank leaks.
JB Weld might be fine.
Old Sep 9, 2011 | 10:31 AM
delta254's Avatar
ok ill look for it today thank you.
Old Sep 9, 2011 | 11:14 AM
Clean it well, and it will probably work best with the gas OUT of the tank (no pressure pushing against your repair). Also, taper the edges of the putty and smooth them into the surrounding surface.
Old Sep 9, 2011 | 01:14 PM
delta254's Avatar
clean it well, and it will probably work best with the gas out of the tank (no pressure pushing against your repair). Also, taper the edges of the putty and smooth them into the surrounding surface.
- eric
will do my mechanic knows a place that cleans and welds them but at this point i just want a simple fix when i get the car paitned ill take it off and have it done thank you...
defiant1
Mar 16, 2015 09:44 AM
TOM1972
Jan 2, 2015 12:29 PM
lvelocci
Body work
Nov 15, 2010 11:05 AM
lvelocci
Body work
Nov 14, 2010 06:06 AM
bgoble
Apr 19, 2010 04:18 PM
