Leak behind rear driver side tire (water)
Old June 3rd, 2012 | 11:14 PM
DeltaDevil88's Avatar
Today was pretty warm in Dallas so I had the A/C cranking usually of course when I park the car I notice water below the front on my car from my A/C components which is normal from the heat.
But I also noticed today behind my rear driver tire some water as well any idea how or why its there?
Prob a dumb question but I was a little worried and perplexed
Old June 4th, 2012 | 04:30 AM
There is nothing in the back of your car that contains water (except, in my case, the trunk, after it rains ).
Old June 4th, 2012 | 06:05 AM
Lady72nRob71's Avatar
Perhaps it was from the A/C drippage, flung backwards from the winds of moving forward?
Old June 4th, 2012 | 07:42 AM
Rickman48's Avatar
Condensation from the exhaust?
Is it near the pipe?
Old June 4th, 2012 | 08:04 AM
66400's Avatar
May be from a leaking back window. Look inside the trunk drop off where the lower rear quarter panel is connected, you may have a pool of water there.
Henry
Old June 5th, 2012 | 03:05 PM
Trunk seals are great and dry as a bone also window has no problems.....I think Rob might be on too something even though its odd it would be flung from the passenger side on the engine to the rear driver side tire.
I got this response from the gbody forum
There is a drain hole in that location. If it hasn't rained recently and you have washed your car then check your trunk. Leaking in my car at that location was caused by windshield washer fluid leaking from it's container
I'm out of town when I get back to TX I will double check and post pics.
Old June 5th, 2012 | 04:13 PM
Maybe a dumb couple of questions, but here goes.
1. Any chance it could have been a gas leak and not water??
2. Are the rear shocks leaking?
I know the spout is at the back of the car, but my 83 Ninety Eight developed pinholes in the top of the tank and leaked out there, dropping down to the ground just behind the right rear tire. Anyway, just some shots in the dark.
Old June 6th, 2012 | 12:33 AM
Definetly not gas put my finger in the fluid clear with no smell, shocks are fine they are original in a 70k car.
Old June 6th, 2012 | 12:12 PM
Well those 2 are good news. So is this fluid a little bit slippery if you rub your fingers together? The only other thing I can think it would be back there is brake fluid. Check to see if there's any sign of leaking from the rear backing plate, and also check the front brake fluid reservoir to see if it's full or down somewhat.
Old June 12th, 2012 | 06:44 PM
Its 100% water and its dripping from out of this hole pic is behind my rear driver tire.
Old June 12th, 2012 | 07:16 PM
Does this car have a sunroof? It is possible the water drain hoses go back there and that one is partially clogged... If not, time to pop the trunk and trace it back uphill. Maybe a hidden bottle of water that has sprung a leak? Trunk seal lip has a rust hole allowing water to ender and collect?
Old June 12th, 2012 | 08:20 PM
I'd be inclined to thing what Rob said. I had a drain problem like that on my 83 Ninety Eight Regency Brougham. If it is a drain problem, git'r done. Mine ended up getting plugged up and I didn't know till after a very heavy week of rain. It was a disaster.
Old June 12th, 2012 | 09:46 PM
This just goes to show Rob gives the best car advice I've ever seen off a forum......Turns out a gallon of water was hiding in my trunk
how you guessed it Rob I don't know but thanks.
Old June 13th, 2012 | 07:43 AM
66400's Avatar
If you paid attention to your replies I told you the same thing on June 4.
Henry
Old June 13th, 2012 | 08:20 AM
So now the question is how did the water get in there and why did it not drain quickly.
So was it a bottle of water that was leaking? Sometimes people would carry some in case it was needed to add to the radiator. There are cardboard flaps over the quarter areas, under the mats in the trunks of these cars that make good hidden storage places for stuff like this. I stuff old but usable belts and hoses in them, in case of a roadside repair is needed.
Lady brought back 2-3 gallons of rain water from South Carolina when i drove her home.
I heard some sloshing noises when I would brake. When I got home I found out that the rear quarters had 4" of mud in them! There was a lot of cleaning afterwards...
Old June 13th, 2012 | 08:59 AM
... And I said the same thing 3 hours and 34 minutes before you did, at 06:30 on June 4th .
But does anyone listen to me? Noooooooooo!
Old June 13th, 2012 | 11:24 AM
Sorry guys yes it was a slowly leaking 2 gallon container of water.
Old June 13th, 2012 | 07:36 PM
So do we get to laugh at you?
Old June 13th, 2012 | 09:20 PM
Looks like you were wrong my friend - there was something!
He was out of town and probably did not see the replies until the picture was posted.
Looks not - I won the guess at it being a leaking bottle of water...
Old June 13th, 2012 | 09:25 PM
66400's Avatar
What an easy fix! Henry
Old June 13th, 2012 | 09:32 PM
Laugh all you want! Was embarrassing but just glad it was a easy fix.
Old June 14th, 2012 | 04:36 AM
Okay, I should have said "nothing from the factory..."
Mrgadget
February 24th, 2015 10:30 PM
63super88
April 6th, 2014 07:51 AM
vette442
May 8th, 2012 09:23 AM
TheRuss
Brakes/Hydraulic Systems
March 26th, 2012 10:49 AM
yeahbuddy
April 9th, 2010 04:48 PM
