J88 cowl tag ?
Old Jun 10, 2016 | 08:00 PM
jetstar88convertwi's Avatar
J88 cowl tag ?
Can anyone decode my Jetstar 88 cowl tag? How do I know which engine was in this car? I know it was a 330 but someone changed the intake and carb to edelbrock. Im not absolutely sure if its still the original engine. Is there anyway to ID the engine from the heads or block? Im a complete newbie to the Oldsmobile World so Im sorry if I am asking basic questions.
Old Jun 11, 2016 | 11:49 AM
jaunty75's Avatar
I don't know all the codes, but
33 = Jetstar 88 series
67 = convertible body style
04D = 4th week of April 1964 build date
994 = red vinyl interior
PAINT C = provincial white lower body color
PAINT 1 = convertible top color, but I don't have this
C60 = ?
I also don't know what the "1" between the 994 and the word PAINT means.
Does any of this match up to what your car looks like? Can we see some photos of it?
Someone else will chime in about the engine.
Old Jun 11, 2016 | 01:24 PM
C60 = ?
C60 is air conditioning.
Your April build should have No. 1 heads with the 1964-only shaft-mounted rocker arms. Oldsmobile did not start stamping the VIN derivative on the block until the 1968 model year, so there is no way to prove if your block is original, only that it is the correct casting number. If you have the Protect-O-Plate, the engine unit number on one head will match the P-O-P, but that just proves that one head is original.
Old Jun 11, 2016 | 01:37 PM
jaunty75's Avatar
Interesting. That had to be a rare option on a low-end 1964 convertible. I know it's an Oldsmobile, which by definition is not really "low-end," but still, A/C was still quite a luxury at that time in any car, and for someone to buy it in a convertible that wasn't a Cadillac or Ninety-Eight or something similar, had to be unusual.
Old Jun 11, 2016 | 01:46 PM
Factory A/C installations went from just over 400,000 in the 1960 model year to 1.4 million in the 1964 model year. Not as rare as you might think. Yes, luxury cars were more likely to have it, but it was certainly available on the J88. At $430, it was not a cheap option, however.
Old Jun 11, 2016 | 02:08 PM
makes sense
C60 = ?
I discovered today that it is not the original engine, from what I have read it looks to be a 76 350. Am i correct? It did have A/C and was at one point white.
Old Jun 11, 2016 | 02:14 PM
overall seems to be a solid car
A lot of work has been done before I bought it but still could use more. Paid $8000 for it. Thinking it may be too much but I like it so it I guess it don't matter.
Old Jun 11, 2016 | 03:09 PM
Yes, that is a 1976 model year 350 from a car assembled at the Arlington, TX assembly plant. Does it have the 1964-style water pump (lower hose on the driver's side)?
Old Jun 11, 2016 | 03:31 PM
yes it does is that good or bad?
Old Jun 12, 2016 | 06:49 PM
btw's Avatar
btw
Smokin' BBQ Member
My D88 was a 4C64 build. No A/C though. Not sure what the Paint code 1 is. A is black which corresponds to your photo.
Old Jun 13, 2016 | 06:25 AM
Neither. I was just curious. The 1964 water pump is one year only and can be difficult to find. Also, the timing tab is on the passenger side and thus the balancer is different. Did they put the 330 balancer on the 350? Or did they re-scribe the timing mark on the 350 balancer? Or, did they just blow it off and do nothing?
88jetstar
Dec 4, 2014 09:44 AM
88jetstar
Jun 2, 2014 10:36 AM
88jetstar
Apr 22, 2014 01:43 PM
rennoc442
Aug 30, 2013 09:23 AM
aliensatemybuick
Sep 23, 2010 01:05 PM
