How rare are disc brakes on a 69 Delta 88 ?
Old Apr 5, 2008 | 03:46 PM
DennisG.'s Avatar
Just curious how rear disc brakes are on a 69 Delta 88 and what else will they fit, b-body wise ? They have the 5 on 5 bolt pattern. I am parting the car out if anyone is in the market for a setup.
Dennis
Old Apr 5, 2008 | 04:14 PM
rocketraider's Avatar
Oldsdruid
They're not common for sure. They'll work on any 65-70 B/C body car. The kicker is if anything needs replacing, the stuff doesn't exist. Make sure you pull everything from master cylinder to pads including brake lines.
Old Apr 11, 2008 | 09:13 PM
russell7088's Avatar
disc brakes
where are you located
can you have these checked out for thickness
Old Apr 13, 2008 | 10:41 AM
DennisG.'s Avatar
I found some conflicting stories. Some say they will fit any 65-70 b-body. Others say the Buick are Buick only and the Pontiac are Pontiac only, as well as the Chevys. I don`t see how or why GM would have made them all different considering all the A-body d/b setups interchange. The car is located in Trenton Michigan. I`ll try to check the dissgard monday or tuesday but I won`t sell the rotors seperately unless you buy the whole setup and only want the rotors. I listed the d/b on ebay.
http://cgi.ebay.com/ebaymotors/69-Ol...spagenameZWDVW
Old Apr 13, 2008 | 07:01 PM
Oldsdruid
Dennis, I mis-spoke myself. I meant any 65-70 Olds B/C body. The Divisions were notorious for going their own way on brakes/suspension thru 1970.
Old May 20, 2008 | 12:23 PM
ramnation1's Avatar
anyone know how to get in touch with this guy? I need those brakes! LOL I have been wanting to change out to the disc for 6 years now... PLEASE have him get in touch !
Old May 21, 2008 | 10:53 AM
bcg88's Avatar
I have seen that Stainless Steel Brakes also makes a drum conversion kit if you are interested.
68 D88
Aug 18, 2020 12:47 PM
joeculhane
Brakes/Hydraulic Systems
Sep 1, 2014 04:46 PM
oldspackrat
Oct 3, 2012 05:54 PM
RATCHETMASTER
Jun 24, 2012 10:21 PM
DennisG.
May 2, 2008 02:43 PM
