How much do you know?
This is a puzzle to test your knowledge of engines. This is what happened with my 56 Olds, 324 engine. All the info is here and I will post the answer in 3 or 4 days to give everyone a chance to solve this. Info: The engine was torn down including crank removal. Heads re-worked with hardened valve seats and .060 removed from the heads. Installed new timing gear, new chain, new after market cam,new hydraulic lifters. The distributor was removed and rotated to a different position to provide clearance for the new carb linkage.
Problem: The engine tested zero compression on all cylinders after re-assembly. What do you think is wrong and how would you fix it?
P.S. A buddy of mine solved it for me. Chuck
Somethings holding the valves open or the timing is way off...chain/cam is 180* out. If 180 out Id still think youd see some compression on a couple of the cylinders. Its likely the head shave...Did you adjust the valve train geometry to compensate for the 60 thou shave? If not you need custom push rods and/or shims under the rockers.
It could be a few things but if all the parts are good and were properly installed (gaskets, rings, etc) then I would surmize;
Valves are not closing all the way / seating
A quick bit of air pressure in cly#1 at TDC would let you know where most of the air was escaping through.
how much do you know
I would check the distributer to the original position and start compression checks again....I think? I would reset the distributor to the original position and redo the compression check
I think everyone who said push rods is right. This is one of those things that should have been checked. If you didn't check it, it probably went wrong. Any time you do ANYTHING that will change rocker angle geometry, you need to check it, and correct it if wrong by getting different rush rods or shimming rocker pedestals. Correct rocker geometry should ALWAYS checked on ANY rebuild.
Could also be cam in wrong place, but that is a more obvious mistake than push rods too long.
Yes the problem was corrected by making 16 gage shims for under the rockers. I measured the bolt spacing carefully and made the shims close enough so they couldn't shift and block the oiler hole. Chuck
kevin.horton
Nov 12, 2018 09:03 AM
