Help, what is this? Check Images- Need Info
Old Feb 26, 2007 | 07:55 PM
frdmftr's Avatar
Freedom Fighter
In the past week, all of you have helped me identify (at least I'm closer) the beast that lies within (under the hood).
I have attached some pics that I hope you can help me lasso this animal.
Here is what I have for specs/eng codes-
388242D front of block
'C' code on head
The left exhaust exits the center of the manifold, crosses underneath the oil pan (factory relief it appears) and aligns to the right exhaust to run parallel aft, separating along each side of driveshaft, jumping over rear diff, coming out the rear looking very clean, neat, normal . The real oddity is the right side manifold has 'two' outlets, one aft with the pipe, one forward that appears to have a 'plug' installed .
Take a look at the pics and offer any info/advice/warnings you feel I need.
Thanks again for bringing me up to speed.
Dave
(FRDMFTR)
Old Feb 26, 2007 | 08:06 PM
texasred's Avatar
Tom Servo's Stunt Double
Take another look at those motor numbers...I had to magnify the pic to see it...but they are really 389244D, which is a 66-67 425. 'C' heads were used 67-69.
The exhaust? That's for somebody else to answer.
C.J.
Old Feb 26, 2007 | 08:10 PM
frdmftr's Avatar
Freedom Fighter
Thanks, my bad (eyes). Thats why this site is the best!
Old Feb 27, 2007 | 08:13 AM
Oldsguy's Avatar
Past Administrator
I think the exhausts are someone's solution for a true dual setup from a stock single exhaust. from your description about the driver's manifold having a plugged opening and all. Looks very clean though and if it works, it works.
Old Feb 27, 2007 | 11:24 AM
frdmftr's Avatar
Freedom Fighter
Thanks. The pipes back to the tips are all new and a very clean installation. It works well and I don't need to anticipate spending the $$ for a new set. I can put the $$ to areas that need it (though not much else is needed)
Old Feb 27, 2007 | 11:07 PM
mwmjr's Avatar
It appears that we have the same engine. I believe it is a 1967 425 that oldsmobile used for their big cars.
Let me know if you learn anymore..
Old Feb 28, 2007 | 06:53 AM
70Wcars's Avatar
Looks as if the exhaust was routed thru the " bump " in a Toronado oil pan...normally where the axle would go in the front wheel drive applications. Again I would need to see the " drill spot " on the top of the timing case to be sure, but my bet is this is a 45 degree engine block used in Toros to allow for lower hood lines.
Hope this helps
Old Feb 28, 2007 | 08:58 AM
frdmftr's Avatar
Freedom Fighter
I looked last night for the spot you mentioned. Is this located on the timing chain cover, next to the oil filler? I agree that this is a 425, C heads (67) and most likely from a Toro. Everything runs great, no issues at all. I don't plan to do any more than is there (Edelbrock carb, manifold, and dual exhaust). I'm just getting specs for the 'just in case' I run into problems in the future. I plan to focus on the minor body details (alignment of steel and minor trim replacement).
Thanks everyone for the knowledge.
FRDMFTR
Old Mar 2, 2007 | 10:34 AM
frdmftr's Avatar
Freedom Fighter
I see a lot of posts recommending the 455 'W-30' exhaust manifolds. I'm sure they are hard to get OEM but is there a company making new ones? Something to store on a shelf if/when I get around to running new tubes out of the 425 in my ride.
Old Mar 2, 2007 | 02:18 PM
Oldsmaniac's Avatar
If this 67 engine is in a 67 88 wouldnt it make sense that it is the original engine or do you know surely it was changed? A toro engine is a 39 degree block. C heads are 67 to 69 vintage big block heads. as for the exhaust it is surely someones customization for true duals.....W-30 manifolds wont work on a 67 B body car. The correct driver's side manifold is reproduced and available.
Old Mar 2, 2007 | 08:04 PM
frdmftr's Avatar
Freedom Fighter
Answer a question with a question?
I don't have the history or background on this car. I also don't have a lot of 'Olds' knowledge and look to 'senior' members help, when offered. My engine questions are derived from the obvious conversion to dual exhaust, and a rather trick on at that. I'm assuming the following:
1. the 67 425ci was either 2 or 4 barrel carbed. The engine I have is now equipped with aftermarket intake and carb (both Edelbrock). Without knowing the original configuration, I cannot verify its origin.
2. They either were single pipe or duals. I am told that all duals went aft on opposite sides of the engine (not crossing over like mine has been routed). My concern stems from the drivers side crossing underneath the oil pan through what I assume is from a Toronado as it has the relief in it. I cannot believe that the single exhaust 67 Delta 88 had the same cross-over as the Toro did. Or am I way off-base?
3. I can only assume then that if I have a Toro oil pan, exhaust manifolds form a Toro (not verified either), and connot verify what the original intake (low profile) was, I can only assume the entire motor was from a Toro of the same vintage (1967).
That leads me back to the last post. Where (links, names, etc...) can I find the reproduction exhaust manifolds?
FRDMFTR
3.
Old Mar 3, 2007 | 06:27 AM
Oldsmaniac's Avatar
The repro, correct manifold often turns up on Ebay but can be bought from Thornton Reproductions....they specialize in 442 stuff but do have the S manifold. Im not convinced the oil pan is from a Toro....the car could have came with a 2 or 4bbl carb both of them single exhausted. The only way the car came with fact duals is if it had the Starfire engine. If it did most likely you would have the correct manifolds. The manifolds on your car are not Toro but single exhaust manifold(s). The passenger side manifold is the same for single or dual exhausted cars....the center hole on the passenger manifold is capped from the factory for duals with a bolt on cap. If nothing can be solved at 442.com with block numbers I would assume the engine is not Toro and the original one that your car was built with. A Toro oil pan gives and extra quart of oil....a lot of people in the 70's would swap pans for the added protection of another quart of oil. The sure way of telling if it is a Toro block is to pull the intake and measure a lifter......all Toro 425's had a
921 diameter lifter while the standard 425's had a smaller .842 lifter.
Old Mar 3, 2007 | 07:28 AM
OldsMotion's Avatar
OldsMotion
FRDMFTR
3.
Fusick or BAP is selling repros of those manifolds. W/Z manifolds I think???
www.fusick.com
www.oldsparts.com
John
Old Mar 3, 2007 | 08:11 AM
frdmftr's Avatar
Freedom Fighter
I really appreciate the information you have given me. I learned alot and am confortable in stating that this engine is OEM to this car. I did the research in both 442.com and Wikipedia (surprisingly lots there, just watch for junk posts) as you all suggested. Good thing is it runs great and I don't anticipate tearing into it anytime soon.
Now all I need is for the weather to break its grip,
Happy Cruising........
FRDMFTR
Old Mar 6, 2007 | 07:37 PM
Oldsguy's Avatar
Past Administrator
Thread necromancy here, I looked at those pictures again and the crossover of the driver's side is just like the stock single exhaust was done, except that the pipe does not join with the passenger side and instead passes to the aft of the car. Therefore I think the pan is a stock non-toro pan, it also looks identical to the pan on the 455's I own. I can't say for sure that it isn't a toro pan though.
Finally, as you said in your last post you are comfortable with it and it makes you happy. When the weather gets warmer you will probably find out for sure. It is still very nice and the work is well done.
BTW, for what it is worth, I just wonder how much heat is radiated into the oil pan from that crossover running underneath it? Probably doesn't make a lot of difference.
Old Mar 7, 2007 | 07:48 AM
frdmftr's Avatar
Freedom Fighter
Thanks Oldsguy. I've learned alot in just two weeks with your help.
I feel confident now that this is the original engine and was 'converted' to dual exhaust via bypassing the rt side manifold. I was really confused (ignorant) by the oilpan as it had the relief I believed to only apply to the Toro's. I know better now.
As for performance, I've had it out a couple times, and finally with top down. It runs out very nice and from 60-90, its friggen' scary (according to my wife). she did not appreciate the demonstration.
FRDMFTR
Miles71
Apr 30, 2014 04:32 AM
gregorcarp
Site Help
Oct 17, 2012 04:25 PM
BigBertha442
Apr 11, 2008 04:56 PM
