HELP! need a fuel cell that takes a 30 ohm sender
Old Feb 8, 2018 | 07:18 AM
bkcraun's Avatar
I'm hoping someone here has seen such an animal. I'm going to drop in a 15-18 gallon fuel cell, but I need a cell that will accept a 30 ohm sending unit. I plan on buying the sending unit and the cell. Problem is all the cells I've looked at have holes for 90 ohm sending units (holes are too big). I'm hoping there a parts guy on here that may be able to lead me in the right direction.
Got a 64 Dynamic 88 and no tanks are available. Mine is beyond repair.
Thanks!
Old Feb 8, 2018 | 07:35 AM
Thanks!
Given that GM has used 90 ohms from 1965-up, it's doubtful you'll find such a cell. You can have a custom tank made by a vendor like TANKS, Inc. You can make an adapter ring. You can use one of these resistance converter units.
Old Feb 8, 2018 | 10:22 AM
bkcraun's Avatar
Thanks Joe! If I can't find a cell that will work, I'll probably go this route. $130
Old Feb 9, 2018 | 10:00 AM
bkcraun's Avatar
Going with sort of a universal tank from Tanks, Inc that will fit in the trunk depression and they have a 0-30 ohm sending unit for it! It's a 22 gallon tank.
Arrowstorm
Jan 28, 2016 06:56 AM
oldsman72
Aug 25, 2015 09:44 AM
Jamesbo
Jun 20, 2010 08:34 PM
jaunty75
Jan 27, 2010 12:59 PM
ozoneblue
Jan 10, 2010 06:07 PM
