Are the Chrome trim pieces on a 1983 Delta 88 Glued On or??.
Old Feb 27, 2011 | 10:27 AM
MASH4077's Avatar
I really dislike the chrome strips that are on the side of my 83' delta 88.
Does anyone know if they are glued/taped on or do they go through holes in the body?.
I wanna try and get it painted this summer and Im hoping I wont have to fill in holes from the chrome pieces.
Also if there are holes under the chrome how do you fill them?
Thanks in advance..
Old Feb 27, 2011 | 12:36 PM
car_designer's Avatar
Are you talking about the chrome strips with the rubber/plastic in the middle?
If so, they were taped on when I took them off my 83 Delta.
Old Feb 27, 2011 | 03:52 PM
MASH4077's Avatar
Yes those are the ones.
Thanks for the info, I will go ahead and pull them off tomorrow..
Old Mar 10, 2011 | 02:16 PM
MASH4077's Avatar
Okay. I got the ones on the doors pulled off, but there is also ones on the very bottom of the door that is about 3 1/2 or 4 inches wide, and the one going down the center of the hood. does anyone know if these are riveted on or are they also glued on?. I dont wanna risk trying to pull them off if there riveted.
Old Mar 10, 2011 | 07:50 PM
I think the strip down the middle of the hood is actually bolted on. Under (technically above) the hood insulation you should be able to see a bunch of sheet metal nuts.
Old Mar 11, 2011 | 03:19 AM
Yellowstatue's Avatar
The trim along the bottom of the door and rockers is fastened on with plastic clips which are stuck into holes in the car...
Old Mar 11, 2011 | 03:54 PM
MASH4077's Avatar
Yeah thats what I was afraid of,
I guess I will leave those ones on until i get closer to getting it painted.
Old Mar 12, 2011 | 06:44 AM
kbgood's Avatar
At least yours were glued on , someone screwed all our trim on with black sheet metal screws right through the black centers of the trim. We will have to fix that this spring when we take it to be painted.
Old Oct 4, 2013 | 10:28 AM
88Deltakid's Avatar
I hate to resurrect an old thread but where can that trim be found that runs down the middle of the body line?
Huntah67
Apr 7, 2014 07:02 AM
oldspackrat
Apr 4, 2014 09:39 PM
Colpage1
Mar 20, 2013 05:48 AM
esisson
Aug 4, 2008 05:27 PM
