change tail lights '84 delta 88
Old Sep 22, 2006 | 01:24 PM
ztim's Avatar
Question change tail lights '84 delta 88
Where is the wiring harness and opening to change bulbs? It seems sealed off from the trunk.
Old Sep 23, 2006 | 08:49 AM
ozoneblue's Avatar
tail lights
Remove the black plastic wing nuts inside trunk then remove tail light assy
Old Sep 27, 2006 | 07:15 PM
ztim's Avatar
I took them off and the nuts and washers. That thing is sealed on very tight. The screwdriver I tried to pry on it with just bent metal. I did find the wire bundle to tie the trailer lights into and there was a cannon-type connector. All this was on the lower left side of the trunk. The wire color code is what is stumping me now. It does not match the wire colors of the lights.
Old Sep 28, 2006 | 04:38 PM
ozoneblue's Avatar
Yes it does brown green & yellow White is body ground .Your best investment would be a 12 volt test light
Old Sep 30, 2006 | 04:54 PM
ztim's Avatar
OK. I finally got it. The wing nuts are in the inside of the trunk and the assy comes off from the outside. But that still does not help with getting to the back up lights. Any ideas?
Old Oct 7, 2006 | 02:18 PM
ztim's Avatar
Ok...back up lights can be gotten to underneath the car..
carnell71075
Apr 12, 2015 04:09 PM
Oldssupreme
Apr 3, 2015 08:36 PM
JATA
Jul 10, 2013 06:46 AM
oldstuff
Sep 13, 2011 08:03 AM
Sid
Sep 10, 2010 02:33 AM
