B-Body springs
Old Sep 18, 2007 | 07:48 PM
Redog's Avatar
B-Body springs
Will springs that are for a 90 to 96 Impala fit an 85 Delta?
I thought all B-Bodies from 77 to 96 have the same mounting for srpings
Old Sep 19, 2007 | 08:52 PM
Redog's Avatar
*bump, bump*
Old Sep 19, 2007 | 10:40 PM
The 91-96 B-body frame is almost identical to the 77-90 frame, so yes, they should fit.
Old Sep 21, 2007 | 01:35 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Mmhmm. I have 96 imp rears in my 85 delta.
Old Nov 16, 2007 | 09:35 AM
Redog's Avatar
Thanks!
Eibachs FTW
Old Nov 19, 2007 | 01:07 PM
fast68's Avatar
easterwabbit
91-96 is virtually identical to the 78-90
78 is technically the new year although the 77 body is the same on most models of b body
77 and 78 were changeover years and kinda odd
some changed for 77 and others didnt til 78
even on the same platform
if you look up brake parts and some other chassis related parts they differ 77 to 78 on the same models/platform
very confusing
most sources list 78-96
Old Nov 19, 2007 | 01:53 PM
very confusing
I'm not sure what sources you're referring to, but all B-body cars changed to the "downsized" platform in 1977. There's no ambiguity about this. The lighter duty versions used the same 4.75" wheel lug circle and small brakes as the older A-body cars. The heavier duty versions (wagons, police, taxi, etc) used 5" lug circles and bigger brakes common to the 71-76 cars. Coil spring diameters were common between the 71-76 and 77-up cars in some cases anyway.
bigjaythe1st
Suspension & Handling
May 8, 2012 05:45 PM
J-(Chicago)
Nov 7, 2011 08:19 AM
yankees
Oct 18, 2011 08:43 AM
1acesmith
Aug 11, 2011 11:03 AM
Texas442
Mar 5, 2011 10:20 AM
