any 1968/70 350 powered 88's
I am looking for factory exhaust manifolds & crossover pipe for a 350 from these years. I remember looking at a 1969 rotted out Delta that was 350 powered about 15 years ago. Some Delmonts in 1968 & Delta's in 69/70 had 350's. I'm wanting to 350 "power" a C body (98). The rear steering box will hit the later (71/76) 350 factory manifolds. I'm looking for the correct manifolds numbers. I trying to plan out a future project. Thank, Ken
Right, you need the center dump LH manifold
Probably the BB manifolds A and R or T will do for you. I think there might be a center dump number-ID small block specific LH manifold, which would match a #3 or 4 RH unit,
Aye
Casting ID "2", 380145
"MANIFOLD, Exhaust, LH, ID= "2"
First year of issue LH center dump? Big Car w/ 330?
1964-68 F85 or Jetstar 88"
I have a 64 J88 for parts, but if you can use std issue BB manifolds A-T or A-R then just do that.
Aye
Thanks for the info Chris. I have the big block manifolds stashed away. I wasn't sure if they would fit properly on a small block. I'll have to try installing a set on a 350 prior to installation. I only personally saw one 350 Delta but they did put 350's in the Delmont/Delta between 1968/70. Thanks again. Ken
Thanks for the info, it gives me a few more potential candidates to look for. Probably the majority of these years were demo derbied or scrapped. I have a possible candidate. Ken
costpenn
September 20th, 2014 06:21 AM
1k442
August 23rd, 2012 12:15 PM
dhartley72
March 24th, 2011 05:38 AM
