after some info on 63 88 script
does any other year lettering match the 63's looking for hood and trunk letters already figured out dynamic script one year only. still gotta fin some of them. thanks
Early 62 's used letters with a smaller stud . Probably not a concern , should fit anyway .
I can't give you any info on the rear letters , as my body parts book is at my shop . I'll try to get that for you tomorrow .
Anything from a 57 thru 70 big Olds , or Pontiac should fit .
Besides the obvious difference in the shapes of the taillights, the "Oldsmobile" lettering on the rear of the '63 and '64 models is different. The '63 model has the letters applied directly to the sheet metal while the '64 has them on a polished metal plate. I'm not sure whether the letters are molded into the plate or are attached individually. If the latter, there's a good chance they're the same as the '63
The 1972 parts book lists 1963 88 exc S/W rear trunk letters . As part numbers 4886764 thru 4886771 , for letters O,L,D,S,M,B,I,&E .
Looks like they are all by themselves .
ninety eight
Ninety-Eight
Mar 1, 2012 03:02 PM
62CUTLASSINKEYWEST
Aug 20, 2009 11:48 AM
