85 hood edge trim yellowed
Hey everyone ...
Hood edge trim on my 85 Delta 88 appears to be wrapped in some kind of plastic that has turned yellow. See pics below. Is this plastic supposed to be there? Can I remove it? It looks to be the only piece on my car with this plastic, so it doesn't match the rest.
^^^THIS! It's probably the same aftermarket stick-on trim that is used on your non-factory half vinyl roof, too. Not much you can do except replace it. The yellowing is in the plastic coating that is on top of the "chrome" applied to the plastic trim.
I'll try this again. The yellow is the clear plastic outer layer aging. The only way to "make it go away" is to remove it. Lacquer thinner on that plastic coating will definitely make the yellow go away, since it will dissolve the plastic.
Your photos aren't clear enough to show any clips holding the trim in place... I have a rear hood trim piece, and it looks nothing like yours... If I get a chance I will take a photo and post it so you can see the difference...
I'm new to these cars, so I didn't know my vinyl top wasn't factory. Any more info available on these aftermarket vinyl tops? Is it best left in place or removed?
The factory didn't install half vinyl tops on these cars, so it's aftermarket. Since it was done by a nameless shop, we have no idea of the quality of the installation. I'm not a fan of any vinyl tops, since they trap moisture and lead to rust. Removing it likely means a repaint, however, so your call.
I have never thought that all the half-landau roofs on 80-85 2-doors (the opposite of a "slickback") were all aftermarket-installed.
Last edited by ReallyWildStuff; September 26th, 2017 at 09:46 AM. Reason: I didn't write what I meant the first time - transposed "dealer" for aftermarket. Sorry!
As I've waited for the Truth Decay Dept to respond - I've thought about this more, and I agree that HALF Landau tops aren't factory.
A 2-door B-Body with a factory Landau top would have a "quarter Landau" - extending from the base of the C-pillar to just above the B-pillar.
A 4-door B-body with a factory Landau top would have a "full Landau" (base of C-pillar to base of the A-pillar).
This is of course no less than Joe said. I apologize for introducing potential confusion.
Napoleon1991
October 6th, 2020 06:42 PM
DouglasOliver
July 15th, 2013 10:50 PM
