71 to 72 Delta 88 nose compatibility
Old Apr 8, 2012 | 05:03 PM
lsutigers93's Avatar
Will a 72 front bumper fit onto a 71 without changing the header panel or grilles? Prefer the 72 look but may be buying a 71 and am curious if the change can be made?
Old Apr 8, 2012 | 05:06 PM
scooter123's Avatar
not sure ...but im looking for a 71 pasenger side headlight bezel......if ya have a spare one kicking around....
Old Apr 8, 2012 | 06:57 PM
jaunty75's Avatar
Not a chance. While the basic look of the full-sized Oldsmobiles from '71 through '76 was the same, there were minor year-to-year styling changes, and the bumpers were one of those areas. Compare the front end of a '72:
with that of a '71:
If nothing else, the turn signals are IN the bumper for the '71 while they're ABOVE the bumper for the '72. There are other major differences as well. No way they would interchange unless you swapped the entire front ends.
If you like the look of the '72, BUY a '72!
Old Apr 8, 2012 | 07:06 PM
As Jaunty pointed out - no you can't just change the bumper. One other thing you need to take into consideration - the 72 bumper had a different energy absorbing system than the 71. To be honest I don't know if the header panels are even compatible. I know 71 is all metal and 3 piece construction and from 72 on is fibreglass 1 piece upper.
Old Apr 22, 2012 | 11:12 AM
Didn't know the header panels were constructed differently, noticed it in the pics...doesn't matter, deal didn't come off...thanks for the info for future comtemplation!
Old Apr 22, 2012 | 11:14 AM
I HAD a '72 Ninety Eight a long time ago...how did I forget that '72s had turn signals in the panel not the bumper...jeez!
Old Apr 22, 2012 | 06:13 PM
Easy, like you said - it was a LONG time ago
Summerof84
May 11, 2015 12:18 PM
StarGeneral
Body work
Dec 1, 2011 07:32 PM
Olds64
Nov 15, 2008 06:30 PM
slimer79olds
Mar 27, 2007 07:29 AM
rustycarr
Mar 21, 2007 07:58 PM
