64 jetstar 88
Old Jan 15, 2014 | 10:27 PM
my second olds's Avatar
64 jetstar 88
How do I know which rearend I have? Of course it's a 10 bolt. But what is the 8.2 or 8.5??
My goal is to order 3.73 gears but I need to what I have first.
Then where do you guys suggest I order from?
Old Jan 17, 2014 | 01:01 PM
mrolds88's Avatar
If it s stock, which it should be, its an 8.2. The 8.5's didnt come out until 71 or 72.
Old Jan 18, 2014 | 04:50 AM
Thanks!
Old Jan 18, 2014 | 05:01 AM
Where can I find these gears?
I've seen some for a 8.2, BOP 1965-71. Would these even work?
Old Jan 18, 2014 | 07:23 AM
Octania's Avatar
Be aware that the '64 J88 is a weird animal with a LOT of one-year, one-model only parts. Rear axles for example. If I had to guess, I would say the differential is more like a Cutlass than a 98, as far as gear fitment.
Time to consult a final drive expert such as Mr. Trick or your local differential folks.
Old Jan 18, 2014 | 11:08 AM
mrolds88's Avatar
Chris is right. The whole assembly is a 1 year piece. But The brakes are Cutlass as is the internal differential parts and the cover. If you would ever choose to go rather high performance, an option is to use a factory 63/64 88/98 big rear. It all bolts up and has a 5x5 bolt pattern.
Old Jan 22, 2014 | 05:50 PM
So any 63/64 out of any 88/98 would bolt right in?
Old Jan 22, 2014 | 07:41 PM
mrolds88's Avatar
Yes. The only things that you may have to do is swap the ujoint and wheels as they are 5x5 bolt pattern. I have one under my 64.
Old Jan 22, 2014 | 09:07 PM
Thanks. Sounds a little easier than trying to find just gears. Now the search begins for a complete rear
Old Jan 24, 2014 | 06:00 PM
Will the rear from a jetstar 1 fit under the jetstar 88?
Old Feb 1, 2014 | 07:36 PM
mrolds88's Avatar
Yes. Any series 88, 98, Starfire and Jetstar 1 63-64.
Old Feb 1, 2014 | 08:16 PM
66400's Avatar
If you are close to Austin, Tx I have a complete drum to drum rearend in a 64 Super 88 that I'd take 200.00 for. Local pick up only.
Henry
What do you think about the driveshaft length?
Old Feb 2, 2014 | 10:18 AM
Henry
Do you know what gears they have?
phoenix22
Sep 17, 2019 03:11 PM
hoppers69
Apr 30, 2012 06:55 PM
66JET
Drivetrain/Differentials
Jan 6, 2007 02:33 PM
Jetstarjockey
May 18, 2006 01:40 PM
<Family Man>
Nov 27, 2003 01:54 AM
