'58 EightyEight Trans Question
Old Mar 28, 2009 | 08:45 PM
Samson's Avatar
I seem to be having an issue with shifting into reverse or getting car to go in reverse, '58 "88" with original 371 and trans, it goes forward okay but when attempting to go backwards I get a sound like it is grinding gears and it does really move could it be something needs adjustment, like shift lever or linkage, or is that sound mean the trans needs some serious work done to it?
Old Mar 29, 2009 | 09:12 AM
88 coupe's Avatar
Junior Member
Originally Posted by Samson
........ issue with shifting into reverse or getting car to go in reverse ........
Idle speed set at 460 RPM, in Drive? Shift linkage too short?
........ a sound like it is grinding gears .......
Low fluid level?
Norm
Old Mar 31, 2009 | 06:00 PM
Samson's Avatar
Umh, It could be trans fluid level... I was on an incline [ well, still am since worried to move car or back up without fear of possibly doing major damage to trans....]
I 'll get the car to a level spot and check both the fluid and the linkage.
Thanks.
sometime it is the simple things you over look, like fluid level.
Old Mar 31, 2009 | 06:13 PM
Samson's Avatar
And I should add in to above post.. perhaps the trans does leak a little, given it's age it would be expected, so I'll check the fluid first, then move on to inspecting for other issues like fixing any leaks and linkage adjustment.
Flye
Apr 18, 2011 04:24 PM
64Super88
May 15, 2010 07:24 AM
Samson
Apr 1, 2009 04:32 AM
loosecannon39
Feb 11, 2009 10:05 PM
delta881972
Aug 25, 2008 02:12 PM
