56 Olds rear suspension
Could someone out there measure the length of the spacer between the rubber bushings on the rear stabilizer bar? My old ones are long gone, and the new ones that came in a kit from Fusick seem to be much too short. This would be the vertical piece that connects the bar to the axle. Just need to know the length of the spacer that is between the upper and lower rubber bushings + or - 1/4 of an inch would be fine. I would sure appreciate it. Thanks, Chuck
