54 Super 88 - Engine block vent question
Old Mar 24, 2016 | 08:17 PM
rctoyguy's Avatar
What should the inside of this vent look like? Mine has a grate like plate inside, but that is all - is that correct?
The car has what sounds like an exhaust leak, but one shop said they believe the sound is coming from here, and they implied that there should be something else inside this canister that would muffle the ticky sound.
Old Mar 24, 2016 | 09:14 PM
redoldsman's Avatar
Proud Viet Nam Veteran
That is the downdraft tube that is designed to carry crankcase fumes down under the car where the draft under the car will carry them away and keep them from entering the inside of the car. I am pretty sure there was one that was just a straight tube. This was what the did in the days before PCV valves. The grate like plate is just a baffle. You just want to make sure it is not clogged.
Old Mar 25, 2016 | 06:40 AM
Rocketowner's Avatar
There's a article on hotrodder.com called Draft tube or PVC that discusses the changing from the downdraft tube to PVC. interesting enough ,I thought you might want to read. Larry
66luvr
Oct 27, 2023 01:39 PM
84oldsDelta88
20
Jan 12, 2016 01:36 PM
Angelov71
Jul 24, 2013 03:30 PM
TicTocTach
Feb 19, 2013 05:16 PM
Mark71
Apr 27, 2011 09:34 PM
