394 question
Old Jul 12, 2015 | 01:28 PM
therobski's Avatar
394 question
The previous owner decided to put a PVC valve in place of the breather pipe pictured. And than ran a hose to the back of the carb. Is that something you Early Olds BB owners do? I just assume put the breather back on.
Old Jul 12, 2015 | 07:22 PM
Charlie Jones's Avatar
Phantom Phixer
I don't see anything wrong with the idea. And it's certainly a lot neater than the original PCV system which made an oily mess of the air cleaner element.
Old Jul 12, 2015 | 07:28 PM
If it just goes to the air cleaner then the PCV is not necessary.
Old Jul 12, 2015 | 07:37 PM
A properly connected PCV valve would be an upgrade.
Old Jul 12, 2015 | 08:34 PM
Tedd Thompson's Avatar
Have you ran the engine without the pcv yet? This was a common fix for excessive blow by on these BBO's.. Does your engine smoke or stink of oil now ...Tedd
Old Jul 13, 2015 | 07:10 AM
therobski's Avatar
No blow by or smoke, discovered also the power brake vacuum lines and canister was disconnected and plugged. I will hook that all back up. He put a T fitting on the back of the carb (2 Barrel) that runs the PVC line and the other to the disconnected vacuum lines for the power brakes. I have the canister and fasteners. I will check it for leaks. Looks like I will have to get help and remove the hood in order to reinstall the vacuum canister.
Old Jul 13, 2015 | 07:14 AM
therobski's Avatar
Charlie, seems the breather pipe on a 62 goes on the passenger side valve cover where the now PVC check valve is. There is a little oil around the air cleaner base, I wonder if that's coming from the oil fill breather cap?
Old Jul 13, 2015 | 07:30 AM
rocketraider's Avatar
Oldsdruid
Find out where the car came from. California cars had a positive crank venting system but IIRC the PCV valve for that was screwed into the carb baseplate and not in the valve cover. Fresh air intake was from aircleaner snout to a special oil fill cap that looked like a Mopar cap.
Possible they couldn't get a screw-in PCV any longer and put a nipple in, and put the PCV in the valve cover. I don't see why this setup won't work fine.
Old Jul 13, 2015 | 07:54 AM
therobski's Avatar
Okay I may leave it. Car originally from Fayetteville Arkansas, believe it or not I have the protecto plate, bill of sale, owners manual and 61-62 shop manuals. I'm stilled puzzled why the Power Brake vacuum canister removed and the lines were plugged.
Old Nov 27, 2015 | 03:40 PM
markmag's Avatar
88
hi, you guys know about FUSICK Olds parts.com..I got a vacuum routing pic from the sit once..
Old Nov 29, 2015 | 01:20 PM
therobski's Avatar
MarkMag, I found one in the 61 shop manual. I can send you a copy if you need it.
theoldsmobilekid
Apr 13, 2022 10:44 PM
trackz man
Dec 13, 2010 12:45 PM
SMOKEYMTNKUSTOMS
Jun 3, 2008 08:54 PM
SMOKEYMTNKUSTOMS
Mar 29, 2006 04:42 AM
