307 cold start issues
Old Apr 30, 2011 | 10:53 AM
DeltaDevil88's Avatar
When ever I try to cold start my 307 I have to prime it first (pump the gas pedal a couple times) before it starts. Warm starts not a issue starts just fine only after sitting awhile does it happen.
Ive been told to just try some carb cleaner first, any suggestions? Sorry to sound noob but its my first carburator engine
Old Apr 30, 2011 | 11:03 AM
henryk8398's Avatar
Hangin' out...
That sounds normal to me. You need to pump the gas pedal to not only set the choke, but provide a little extra fuel for starting. With the quality of the garbage they sell masquerading as gasoline, your float bowl is likely to dry out. That means a few more seconds of cranking to refill it before it can start. Again, sounds normal to me.
Old Apr 30, 2011 | 01:22 PM
X2 as above. With the addition of making sure your choke is set. Also make sure it releases when warm.
Old Apr 30, 2011 | 03:35 PM
Redog's Avatar
That's normal
In the owner's manual it tells you to pump the gas pedal twice, then start the car WITHOUT touching the gas pedal
That's how I started my Delta and it always worked, even with the 350
Old Apr 30, 2011 | 04:37 PM
oldsca's Avatar
Crazy Canuck
This is exactly what you need to and is normal.
Wayne
Old Apr 30, 2011 | 04:53 PM
Doh!!! boy I feel dumb
Old Apr 30, 2011 | 10:44 PM
Redog's Avatar
Not trying to be a wise *** with this question, but how old are you?
My Parents first FI car was a 1991 Cavalier and I was 17
Old May 1, 2011 | 07:34 AM
Lady72nRob71's Avatar
Perfectly normal for a carb engine.
After one to 3 days, one pump is enough. After a week, 2-3 times are needed.
After many months, the float bowl goes dry. One pump to set the choke, crank for 5 seconds, pump 2-3 times, then it should start.
Old May 1, 2011 | 10:10 AM
I'm 26
Old May 1, 2011 | 10:27 AM
Originally Posted by DeltaDevil88
I'm 26
Just the age of your Delta - how appropriate!
I am the same age of my convertible, though I feel the car is in better shape.........
colemane
Apr 13, 2013 01:19 PM
wally74
Apr 13, 2013 12:11 PM
RickH
May 31, 2012 06:59 PM
71supreme
Nov 2, 2010 09:10 PM
yeahbuddy
Oct 6, 2010 11:07 AM
