1990 olds 88 HESITATES
Old Jun 26, 2007 | 04:00 PM
SX455's Avatar
I Have A 1990 88 3.8 Eng 62000 Miles, I Have Changed The Plugs, Wires, Fuel Flt,ect. The Car Feels Like It Has No Power When You First Hit Acc Pedal ,then Surges With Power, Anyone Know What This Can Be Or What Part I Can Try To Change. Thanks
Old Jun 28, 2007 | 09:16 AM
American Lead's Avatar
2Blue 55
I dont know about newer cars, but if it were mine I would get the fuel injection cleaned and that should do the trick for you, let me know how it goes.
Old Jun 28, 2007 | 01:48 PM
eldodroptop's Avatar
I would bet you will need to replace your throttle position sensor (TPS). But instead of just putting parts on your car hoping for the best... PLEASE go to a quality shop and pay for a diagnosis. Yes you will spend about $60 for the privilege but you will save money in the long run.
Old Jun 28, 2007 | 02:13 PM
2Blue 55
I have never herd of a tps, What exactly does it do, I would like to learn more, I don't know much about newer cars.
Old Jun 29, 2007 | 07:57 AM
The TPS is nothing more than a sensor that looks at how much throttle you are using. If you were to push down on the gas the TPS will send a signal to the computer saying in effect "Hey, the driver wants to go faster you might want to add fuel and advance the timing..."
Here is a very good article about the basic operation of a modern fuel injection system.
http://auto.howstuffworks.com/fuel-injection.htm
Old Jun 29, 2007 | 12:37 PM
2Blue 55
Thanks, looks like you can always learn somthing new.
Old Jul 5, 2007 | 07:42 PM
SX455's Avatar
I Replaced The Pigtail And The Tps I Still Have The Same Problem. I Set The Volts At .50 Key On Eng Off Is That Correct Any Other Suggestions. Thanks
Old Jul 6, 2007 | 10:42 AM
2Blue 55
If it was a carb I would say it was an accelerator pump, I would do a vaccum test if you can? I would also get it cleaned.
Dead Reckon
May 25, 2015 07:22 PM
camera1985
Mar 22, 2013 10:33 AM
Miles71
Aug 20, 2012 06:16 AM
PaulDan
Aug 12, 2011 03:29 PM
155thINF
Sep 20, 2006 10:15 PM
