1970 Delta​ 88 2dr windows leak air
Old May 29, 2017 | 06:00 PM
oldsmobilekindofguy's Avatar
I've had my 1970 delta 88 2dr for almost 12 years and have never been able to make it seal up going down the road, even on a none windy day. I had all the weatherstripping replaced a couple years ago and it didn't seem to help much. Both side windows leak air around the front and top, more so the driver's side. Just wondering if there is something I can do to quiet up the cab. Thanks in advance for any advice.
Old May 29, 2017 | 08:27 PM
2blu442's Avatar
Did it leak like this before you replaced the gasket? It either has to be the gasket or glass alignment, do you remember if the new gasket looked like the old one, with the exception of the old one being worn? You could pull the door panel off and play with the adjustment to see if you could make it fit better. But I'm suspect that the gasket you got may not have been the correct one. John
BeenThere
Mar 1, 2017 02:18 PM
Wags
Nov 18, 2015 07:26 AM
74deltavert
Feb 20, 2013 01:19 PM
rustycarr
Mar 7, 2007 06:24 AM
Geoffrey Hacker
Aug 1, 2004 01:05 PM
