1964 fuel pump issue
Old Sep 8, 2025 | 01:02 PM
deaddds's Avatar
Ok, I’m officially pissed. Car will fire if I pour fuel in the carb. Not getting fuel to carb. Pulled the pump and put on a spare. Certainly it could be too old too as I’m not getting fuel with it. But I seem to remember getting the pump arm onto the gd elliptical is a PITA. Any tips before I throw this into the windshield? Not sure if these fuel pumps can be bench tested or not.
Old Sep 8, 2025 | 01:07 PM
Knowing the brand & model number of the fuel pump might assist others who view this thread to garner information relative to quality &/or issues w/ select fuel pumps.
Old Sep 8, 2025 | 01:29 PM
I'd be inclined to test the fuel pressure with each pump installed before throwing any parts at it or tossing anything through the windshield.
Getting the arm in proper contact is just a matter of fiddling and worrying it into place.
Old Sep 8, 2025 | 01:41 PM
I've found use of a mirror & flashlight helpful.
Old Sep 8, 2025 | 01:56 PM
As long as you don't put the pump on upside down, just stab the arm into the hole in the block and it should contact the eccentric properly. The pump body usually can't be pulled flush to the block by hand, and you need to attach the lower (I think) bolt and tighten it until the upper part of the flange comes close enough to the block to get the nut onto the stud.
Old Sep 8, 2025 | 02:31 PM
Is this a 330 or a 394? And do you know if the line from the tank is clear? Try disconnecting the input line to the pump and run a hose into a jug of gas.
rickbmac
Apr 22, 2024 01:17 AM
Oldzman71
Jul 29, 2018 05:41 AM
archeryshooter
Sep 26, 2014 11:39 AM
67442nut
May 11, 2014 09:19 PM
geckonz08
Aug 12, 2008 08:49 PM
