1953 VS 1955 Radiator
Old Dec 11, 2020 | 03:57 PM
F2000Doc's Avatar
Does anybody know what the differences are between and 53 and a 55 radiator? I need a one for my 53 and Walker Radiator has a pattern for a 55 and wondered if that would work?
Old Dec 11, 2020 | 08:25 PM
Charlie Jones's Avatar
Phantom Phixer
According to the Hollander , '53 , '54 , and ' 55 radiators are all different parts numbers.
However in their notes it is reported by auto wreckers that all three radiators would interchange .
It may be possible , but look and measure carefully .
Old May 29, 2022 | 08:29 AM
Navyman53's Avatar
Were you ever able to find a replacement?
Old May 29, 2022 | 08:42 AM
Love1955oldsmobile's Avatar
53 radiator into 55
I put the complete 1953 radiator including shroud into a 1955. Had to drill holes to match 1955 mounting holes.
Ron.
Old May 30, 2022 | 07:59 AM
Navyman53's Avatar
Thanks. I gotta find something to fit into my 53. Very difficult o find anything.
Old May 30, 2022 | 10:22 AM
redoldsman's Avatar
Proud Viet Nam Veteran
I put an aluminum radiator in the 54 I had. It was for a 68 Dodge Coronet. It had the flanges on each side to slide down in the slot and the outlet was on the lower left side. I had to redrill the holes on the flanges once it was in place and use a spacer for the lower radiator hose. I used a spacer on the lower hose because the hose was slightly larger (1 1/2" I think) and the radiator was 1 1/4" believe. The radiator was the correct width (24" if memory serves me correctly). It was not quite as tall as the 54 radiator so I made an air dam to go under the radiator so all the air would go through the radiator. I had to use a flex hose on the top. It worked very well and cooled a lot better than the old radiator which I spent $600 having re-cored into a three core radiator. I measured and studied radiators a long time before I came up with this. I don't remember the brand but it was not a major brand like Be Cool and it was less than $300.
Old May 31, 2022 | 07:44 AM
F2000Doc's Avatar
The fine people at https://classicfordradiator.com/ built a radiator for me. It took some time, but the new unit fit perfect.
Jayjay1
Aug 16, 2020 05:19 AM
Kim Audette
Nov 12, 2017 03:41 PM
Olds Scott
Mar 2, 2013 05:01 PM
50srocker
May 13, 2010 03:02 AM
Olds Nut
Apr 21, 2009 07:42 AM
