Rearend Gears
Rearend Gears
Hello all,
Maybe someone could clear up the confusion for me.I'm going to throw a posi unit in my 72 olds and I'm not totally sure what I have under there.I've heard its the corp. 8.5 and 28 spline.Would there be a reason to think other wise?
Also I want to put 3.73's out back but what's the differnce between those and let's say 4.11's? Are those freeway gears and 3.73's help get you off the line faster?
4.11's will help you get off of the line faster, but raise RPM's on the highway. 3.73's will be slower off of the line but will lower RPM's on the highway.
To be able to help you pick the best gear ratio, we need to know a lot more info about your engine, trans, and tire size. Are you planning on putting a 455 in the car? That will also make a huge difference on what gear will be the best.
Freeway gears would be like 2.56 to 3.08
They would keep your rpms down at speed improving gas milage but are not good for getting off the line quick or racing
.I'm not going to be racing it,mainly just a show car but I want that power to be there if needed!
I just bought a 455 that I'm planning on getting rebuilt and throwing in,in the next few months.I'm either going with the 2004r or the 700r4 and my tire size is 24 inches
So in closing my humble opinion would be 323,331,342.
You are definatly on the right track with the OD tranny.
Why don't you calculate the rpms with a formula to be sure of what your doing
[ and my tire size is 24 inches
It looks to me like your rims might be 24 in. You need the total height of the wheel and tire diameter for the formula
And also remember your overdrive drops the rpms even lower. You'll have to find out what the od ratio is.
.It looks to me like your rims might be 24 in. You need the total height of the wheel and tire diameter for the formula
OD 400th rear ratio
overdrive multiple by .78 on most trannies ...so if you have 24" tires and the rpm is 3000 rpms at 60 then take 3000 x .78 =2340 and then some trannies lock to knock off another 200-300 rpms...and it will give you the new rpm ...remember that auto transmissions have some slip to them always unless you have a lock up convertor on the over drive trans.
If you need a quote on anything rear diff give us a shot then you can compare else where too. Jim
J D Race.com
J D Race.com
monzaz
Drivetrain/Differentials
Aug 7, 2014 11:12 AM
1BAD68"S"
Dec 29, 2007 09:05 PM
