1967 442 post
1967 442 post
What gears were available? Mine has a posi looking to check for code in the next couple days.Will be looking for a few parts later.Project that hasn't been checked yet.
Last edited by wr1970; Aug 1, 2015 at 05:43 AM. Reason: To stop a wise guy attacks
Additional dealer-installed ratios (4.11 and 4.33) from the 67 442 brochure:
Nice post Joe. I have many 66-67 Cutlass 442 parts cars. Email me direct or call with your needs and i will do my best to help you out.
Larry Moyer
Olds Parts and More
Redmond, OR
lemoldsnut@aol.com
calls west coast time 8 am to 8 pm 541-815-4363
Larry Moyer
Olds Parts and More
Redmond, OR
lemoldsnut@aol.com
Geez sorry for the caps...Not yelling...
On the right axle tube between the center carrier section and the right spring mount on the back side there will be a two letter code stamped usually upsidedown that if you provide it we can help with what it came with originally.
Yes 3:08 non-posi. If it is a posi then it was added. I would still pull the cover and count the teeth on the ring and pinion gears. you will see first hand if it is a posi.
here is the codes as I have them.
70 Olds axle codes
Standard type differential
code
R2 2.56
SA 2.78
SC 3.08
SE 3.23
S1 2.56
TA 2.78
SM 3.08
SO 3.23
LIMITED SLIP
R3 2.56
SB 2.78
SD 3.08
SF 3.23
SH 3.42
SJ 3.91
YM 3.42
T0 3.91
ST 2.56
TB 2.78
SN 3.08
SP 3.23
ALUMINUM LIMITED SLIP DIFFERENTIAL
SV 3.23
SX 3.42
SZ 3.91
70 Olds axle codes
code
R2 2.56
SA 2.78
SC 3.08
SE 3.23
S1 2.56
TA 2.78
SM 3.08
SO 3.23
LIMITED SLIP
R3 2.56
SB 2.78
SD 3.08
SF 3.23
SH 3.42
SJ 3.91
YM 3.42
T0 3.91
ST 2.56
TB 2.78
SN 3.08
SP 3.23
SV 3.23
SX 3.42
SZ 3.91
Update numbers on axle rear end housing say it was a 308 .After pulling cover and counting teeth it must be a after market gear it does have a posi unit.The gear is a 390 man am i happy to find that.
Ain't yelling just telling ya all.
