delta 88 posi rearend
Old Mar 23, 2013 | 01:35 PM
scooter123's Avatar
Hi guys my 1971 delta 88 is the old one tire fire and i would like to change it to a posi rearend.
Is there any other GM car that I could find a posi carrier/gears that is interchangeable for the delta???
Old Mar 23, 2013 | 03:11 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Is it the 9.3" 12 bolt cover or the 8.875" 10 bolt cover?
Old Mar 23, 2013 | 03:39 PM
scooter123's Avatar
10 bolt cover.....I have yet to remove the cover....im thinking its still the 3.08 in there that the car came with!!
Old Mar 24, 2013 | 07:20 AM
I have a corporate 8.875 posi rear axle here, I believe from a 78 wagon. It's a c clip 2.73 rear.
I'm willing to part it out if the posi unit will swap over for you, but you will most likely have to use your side gears if it does.
Perhaps monzaz or 507olds will know more info about compatibility.
Old Mar 24, 2013 | 04:21 PM
monzaz's Avatar
years are different
The 1977-1985 Full size cars are really A-body rears from 1973-1977
So you need to stay in the 1971-1976 era of FULL SIZE GM cars.
Buick, Olds, Pontiac, Chevy, even Cadillac NOT WAGONS!
ALL 10 bolt 8.5, 8.875 Pontiac (10 bolt cover 12 bolt ring) and Olds 9.3 (12 bolt cover 12 bolt ring) rears will be the same mounting points for this era of car.
Old Mar 24, 2013 | 05:17 PM
Jim,
Are the B body limited slip carriers hard to come by for the 71 Roger has? He and I chat via email every so often so I get to hear some of the stuff he's going through now. Right now he's in the process of rebuilding his 455. It may stay stock or change CR to 10:1. Either way it's not a drag car, but a damn fine 2 door Royale. Do you have any suggestions for him or can help him with a carrier?
BTW, that series 3 you sold me is finally in the car c/w 3.42's. Waiting till spring to check it out. Thanks for all your help on that BTW.
Old Mar 24, 2013 | 06:06 PM
scooter123's Avatar
Thanks for your input guys.....im not in a hurry for this mod.....just looking to see if there is any straight carrier assembly that would just swap out!!
Been looking on the good old internet for some parts and might start looking in some local auto scrap yards once all the snow is gone and it would be nice to know what im looking for before i go!!
thanks!
Old Mar 24, 2013 | 08:44 PM
monzaz's Avatar
list of cars
The list i gave is the only place your going to get the unit you need. It is pretty large range for a rear 1965-1976.
Jim
I would need to check the shelf. The steep carriers are hard to find. Jim
Old Mar 25, 2013 | 07:25 AM
This one I have was a P-Type I believe. 10 bolt cover 12 bolt ring gear. 8/7/8
Curth
Sep 22, 2010 07:28 AM
reesejames
Jun 6, 2010 05:30 PM
copper128
Mar 6, 2010 11:32 AM
wash464
Aug 26, 2009 05:47 AM
DennisG.
Mar 22, 2008 06:20 AM
