What rear differential should I have in car
Old Jul 10, 2012 | 08:15 AM
77oldsprostreet's Avatar
I just bought a 1976 Olds Cutlass Salon with 350 rocket motor, what rear differential should be in this car from the factory
Old Jul 10, 2012 | 10:07 AM
1970cs's Avatar
Lansing built
I am assuming that you have an automatic? If so 2.41 is standard GU1 code except Z95 code
available 2.56 GM8, 2.73 GU2 and 3.08 GU4. Assuming again that it's Olds/Buick differential
Source Wildabout cars.
http://wildaboutcarsonline.com/membe...2_1-4Z_3.p.pdf
Old Jul 10, 2012 | 05:24 PM
What I meant was wether it was a 10 bolt 7.5 rear or 10 bolt 8" rear or something else
Old Jul 10, 2012 | 07:06 PM
ihengineer76's Avatar
10 bolt 8.5 inch. You can make sure by looking at the bottom of the differential and see if it has two squared off ears cast into it. There are a lot of pictures of this if you google it.
Oldsragger
Jan 7, 2015 08:04 AM
Otto Skorzeny
Drivetrain/Differentials
Mar 13, 2014 07:16 PM
Moose2
Sep 6, 2012 08:42 AM
1970 Post
Aug 6, 2012 05:28 PM
84oldsDelta88
Dec 22, 2009 06:27 PM
